Wiper fuse click noise
Chadd7
12:44 AM
NJ, USA
Has anyone figured out how to silence the annoying click from the fuse box under the rear seats every time we turn on our windshield wipers? Please share.
Find the offending relay and cover it thoughtfully with some dynamat or similar.
It's not an issue I've heard mentioned before.
Slide a piece of Thinsulate SM400L (or whatever thickness you can easily get) over the relays under the back seat, notable difference in sound
How hard is this to do? Sounds complicated from what I’ve read.
With the right relay it's basically quick plug and play. Would take all of 15seconds. I haven't ID'd the relay because it hasn't rained here in forever. But if someone will take the time we can source the correct part. I will do it eventually, just been lazy and not a priority at the moment
My windscreen wiper relais under the rear seats also made this clicking noise every time the wiper moves. This noise disappeared after a while of using the wiper and never came back. Maybe these bosch relais need to wear in. Just be patient.
Glad your’s is ok now but I’ve had my Grenny since Dec 2023.
