Americas Winter tires: Michelin X Ice or Blizzaks?
What are the specs on the rims we need for the IG? I think I’m going to go with steelies again. I don’t A whole different set. Is that smart, or use one set of rims and swap tires? Are there good and bad steelies? It seems like Discount Tire had it so that it was pretty cheap either way?
Swapping tires on and off rims each season isn't great for your tires and the labor cost will quickly eat up savings of not buying wheels. If I were going to run winter tires I'd pick up a set of used OEM steelies that someone upgraded to aftermarket.
That’s what I thought. Especially if I’m looking at steel wheels and not expensive aluminum rims. Talking to my dealer to see if they have any spare ones around. I might just do a swap this time and then have my KO threes put on new rims when I have time in the spring.
As mentioned by @BEM-S4, not a good idea to take the tires on and off - you should have dedicated rims for your winter tires - swap the whole wheel out. I have the steelies for the main part of the year and Black Rhino alloys for the winter. Personally, I prefer a winter wheel that will not cake so much. I thought the steelies got a lot of snow and ice buildup, before I switched to dedicated winter wheels (with coaching from this Forum). Maybe like the AO HD’s. Or maybe Method 703’s or 701’s - just something that has open space on the face. I also have the Owl bracket relocator for the spare, since in winter, I go face out (the spare storage box doesn’t fit in the back face of my black Rhino’s). I believe Discount Tire also sells Black Rhino alloys- and they can reset the TPMS sensors for you when they swap the wheels. The whole process is really simple, and they store the wheels you’re not using in a climate controlled warehouse.
I live in Colorado Springs, where we get hot sunny days in the middle of winter, and then 3 feet of snow the next day. Honestly, I have no issues running KO2s on both my Jeep and the Grenadier. The stock tires are remarkable and totally adequate.
Thank you for rubbing that in right as we head into winter. “In Colorado, we have 30 lb trout that leap into our nets, our driveways never accumulate ice and our flatulence is a rainbow that smells like a fresh spring meadow.”
F that! Trout are SMART! At least compared to Bass and Blue Gills I fished when I was young in the Midwest…
Totally distracting the thread - I taught my little to fly fish this year - started w blue gill and then moved up to trout on the Driftless. We named them “dumb fish” and “smart fish,” respectively.
Got the Nokian Happilittletires TL3 with studs. Put them on my old steelies to give me some time to figure out what I want for my second set of rims. We’ll see what I feel like when the spring comes- though I know some rims are on backorder.
I feel like everyone is looking at me as I crunch along at low speed, but at least it is appropriate for the IG. Since it’s still warm, I’m trying to drive gingerly. The big turning radius helps to keep from twisting the tires…
After putting a lot of thought, tons of reviews etc etc i am going for the michelin x ice on 255/70/18. I really love the ko3 wich apparently i prived a lot in winter vs the ko2 but decided winter tire would always perform better. My wife would mostly be the one using the car in worst conditions so i dont want to risk it at all……
Thanks a lot to all
I have used the x-ice and blizzaks for many years on different vehicles. Lived at 9650 ft in Colorado. I have found the blizzaks to perform much better on ice.
If you ever get the chance go to the Bridgestone winter driving school in Steamboat Springs. You will learn car control on a course that is too slippery to stand up on.
Take the 3 day performance driving school if possible.
Driving on ice will become something to look forward to.
Neither for me - put on Hakkapelliitas LT3's 265/70/17's (not studded) here in NH/VT. Have them mounted on some inexpensive alloys (Nomad Convoys) I picked up online at Fozzie's Wheels (really good experience there with Steve the owner). Have 17" steels for my "other tires" (Cooper ST Maxx's), but wanted alloys for salt resistance, etc... in the winter.
Where in upstate NY? I’m in Saratoga, and so far have been running the factory KOs between here and travels to Vermont regularly go skiing….so far so good, and not sure I’m going to switch to dedicated snows (though we’ll see).
What did you do for TPMS sensors on your second set of wheels?
Thanks
Thanks
I just programmed and installed 9 Autel TPMS senders for my Grenny - 4 on the winter wheels, 4 on the summer wheels and the last one on the spare. I used the hex IDs of the sensors installed by Ineos, so now I don’t have to rely on the dealer when I rotate tires or swap summers for winters. I used their Maxi Sensor model with metal stems. They work great.
Latest posts
