Windshield crack. Second time in 10 days even with ceramic film on windshield
Sprmusic
11:32 PM
San Francisco
I’ve owned an Ineos for 2 months now. I have two cracks appear within weeks of owning my car. I assumed this was the result of a parking ticket left under my wiper blade. However, after replacing the windshield and adding a ceramic film to the windshield, I have an identical crack that has appeared.
Thankful for the film as the crack doesn’t risk the safety of passengers, however the similarities in the cracks and the lack of known source for the second instance of cracking is worrying to me, only similarity is temperatures below 20 degrees…
Why did you add the film?
Yeah not sure what you mean by ceramic film?? They have windshield protection film which is very thick and reduces potential impact from flying stuff, is that what you mean? I have both on mine protection and ceramic film inside to keep the heat out living here in AZ....
A crack due to a parking ticket? You mean a thin piece of paper?
AWo
That must have been a hefty fine...... 🥁
Is it a crack emanating from the middle of the windshield starting at the very edge and extending up? You mentioned the temperature, I’m 99% sure that my crack in the windshield happened because of using the defrost. The car was warm, it was cold outside, and when we turned on the defrost, even my son thought it was very hot. Within about 30 seconds the window got a crack From the very edge right by where the defrost hits.
Reactions: ddv
How does a ticket under the blade cause crack?
The film you put on has no safety utility. Your windshield is already a shatter proof windshield.
