- Local time
- 2:36 AM
- Joined
- Jun 1, 2023
- Messages
- 384
Mine is now fixed. Agent replaced both the nozzles and now is perfect. They think at one point they adjusted them and made the jet nozzle too wide so hence dribbling. New ones are fine. Lesson is to not adjust them without knowing exactly how to do it without damaging the nozzle ends.Windscreen washers have developed a fault - push water but only a half hearted dribble rather than reaching the windscreen. Passenger side one seems to be spiting out around from the base of the jet housing. I suspect pipe has split or come loose here and hence losing pressure across system. Goes on next week so have listed it for a fix along with a few other minor niggles (a/c water leak getting fixed is the big one).
Will update once I know more.
