Americas Wheel specifications for Grenadier & Quartermaster
11:52 PM
Grass Valley, ca
My company would like to make aftermarket wheels for the Grenadier & Quartermaster. What are the OEM specifications for size, offset, load rating & bolt patterns? Do these vehicles have large brake calipers to clear?
Any info would be helpful.
Thank you!
The Grenadier and Quartermaster use a 6x130 bolt pattern, 84.5mm center bore, and ET52 offset. Load rating must be at least 1,375kg per wheel. The large front brake calipers require a wheel design with specific inner clearance.
Thank you!
Dowmnload the Rok Dr Guide, for example
Thank you!
Curious to see what you guys come up with from a design and build quality standpoint. Hopefully you’ll share some prototype concepts on the forum? One suggestion would be to offer different offsets some of which are closer to the stock specifications. Not everyone wants wheels & tires to poke out like a Monster trucks and being able to fine tune the fitment would be ideal.
Thanks guys!
It seems the offset will be the biggest hurdle as it's more positive than most any of our aftermarket wheels. We might be able to make our 17x8.5 +25MM Tacoma targeted wheel work on it. I wonder how much offset change owners are willing to accept?
Does anyone know if there is any brake caliper information out there for these? It sounds like there are large calipers to clear, but how large is large?
Thanks again!
Thanks guys!
Thanks again!
They are apparently Brembo calipers. I think the model details posted somewhere on the forum.
