What fits in teardrop opening in headliner?
cdsvt
9:40 AM
Vermont, USA
I have a factory dog barrier installed in the rear set, what fits the front set?
Ah, thanks. Are those barriers available in the US?
Have a look on the configurator, If the 2 seat is not available in the US then I have a feeling you're out of luck, there are fixing points for the 2 seat that the wagons don't have also.
Thank you. Too bad, as this would be handy offroad. Removing the second row seats and putting a flat platform in place, with a barrier behind the front seats would be the same configuration I run in my land cruiser 80 series. It protects the passengers from projectiles.
What is that for?
Just a grab handle to make entering the vehicle a bit easier on folks. There’s a link To the printable file for the plug in the resource section. I did to mine as well and even though I rarely have tear-seat passengers it was worth the effort.
If I end up using this offroad, I may see if the rear barrier fits the front holes and weld up a frame to attach the bottom portion to. For now the 80 series has pride of place for hard wheeling trips.
There are US companies that have made a kit the replaces the rear seat. Check on this forum for ideas for a cargo barrier, one I've seen was made from ,H/D cargo net with the factory fixing points used.
Goose Gear makes one plate over the second row. Buzz Overland has one that is about to come out. I've used Raingler milspec cargo nets on other vehicles, and had custom ones made by US Cargo Control. Hard barriers make me feel safer, having been in a multiple rollover and seen all kinds of loose equipment become dangerous projectiles.
