Yep, same here.At Bramwell station today. Tiny dust leak at back door, seems to be in the top middle of the big door. Otherwise it's going brilliantly.
Old telegraph track tomorrow.
Beautiful spot.Enjoying the alps between Italy and France.
Bit odd that. Would try a few variations, offroad mode, handbrake off, in drive etcToday I decided to check and test the winch. Pulled out the line in free spool, a bit stiff but did it ok and pulled out to the red marker. All good so far. Turned the remote on and full green light. Green light also flashing as it should when winch in or out is pressed. Vehicle in neutral, hand brake on , 500a switch on overhead console on. Winch lever in verticle/engaged position. Nothing working. Re-paired the handset and tested power at the 150a breaker under the bonnet, all good. Still not working. The solenoid can be heard clicking in when turning on the 500a switch and I have power at the NATO plug at the rear.
Anyone that has ideas please. Winch line out on the driveway and I’m off for a walk withe dog until someone can help me figure what’s wrong.
Thanks in advance.![]()
I would love to help you. But I don't have a winch myself and therefore unfortunately have no experience to pass on to you. Sorry mate.Today I decided to check and test the winch. Pulled out the line in free spool, a bit stiff but did it ok and pulled out to the red marker. All good so far. Turned the remote on and full green light. Green light also flashing as it should when winch in or out is pressed. Vehicle in neutral, hand brake on , 500a switch on overhead console on. Winch lever in verticle/engaged position. Nothing working. Re-paired the handset and tested power at the 150a breaker under the bonnet, all good. Still not working. The solenoid can be heard clicking in when turning on the 500a switch and I have power at the NATO plug at the rear.
I assume the car is on, since you say it is in neutral? Car must be running.Today I decided to check and test the winch. Pulled out the line in free spool, a bit stiff but did it ok and pulled out to the red marker. All good so far. Turned the remote on and full green light. Green light also flashing as it should when winch in or out is pressed. Vehicle in neutral, hand brake on , 500a switch on overhead console on. Winch lever in verticle/engaged position. Nothing working. Re-paired the handset and tested power at the 150a breaker under the bonnet, all good. Still not working. The solenoid can be heard clicking in when turning on the 500a switch and I have power at the NATO plug at the rear.
In my case it is very very stiff. I usually put the lever in horizontal position (free spool) and pull the line out with the help of my remote.Pulled out the line in free spool, a bit stiff but did it ok and pulled out ...
Well, that is also interesting to know!Luckily there is enough room inside outer plastic bumper to store the rope until I get around to getting it checked out View attachment 7865844at the Ineos garage.
I reckon when I get it sorted I could then store my winch extension rope in thereWell, that is also interesting to know!
Depends how long it is! Mine is 25m long, I doubt itI reckon when I get it sorted I could then store my winch extension rope in there
An interesting place for a strollAn evening stroll at sunset on the beach by the North Sea.
You may have given me the true reason for purchasing that step! Well done!Found that the Buzz hinge steps serve perfectly as a wine tumbler resting place for either white or red!
@Wile E Coyote had a problem with the control box which he rectified, I'm sure he'll comment with the solutionWell I’ve tried everything besides taking the protection plate off but can’t get it to work. Changed batteries in hand set, tried handbrake off and in neutral with engine running various combinations but no luck. I’ve never used it before apart trying it on my driveway after I first bought the vehicle.
