We Value Your Opinions! Feedback Request for WolfBox Dash Cam Users
This will probably sound rather insignificant but it may affect other people who live in similar climates to me.
It regularly falls off my back window. The provided adhesive just isn’t adequate in the desert climate (Phoenix, Arizona). And Wolfbox isn’t unique in this problem - adhesives for accessories constantly fail here due to temps up to 117 degrees at times. And even though windows are tinted - it still happens!
As the vendor, I wish you could identify an adhesive that would work in this kind of climate. I may try Velcro but don’t know if that’ll be any better. It’s a real pain when it falls off, especially on trips when you’re on the highway and the cargo area is packed to the roof!
Use the provided screw.
Thanks for your feed back. Can you share a pic showing how you mount it please?
I'm trying to find a 5 or 10m extension for the 4 pin bumper camera. One with one of these at either end:
I have the Tri-Pro installed which I like very much. The only major bit of feedback, for a rearview mirror replacement, the rear camera angle is much too wide. Cars behind are out of expected perspective with regards to judgement of following distance. The angle and magnification should match the glass mirror it replaces insofar as possible.
I used this. First I cleaned the area with alcohol prep wipe on both surfaces and after they were dry, I cut just enough to fit the rear camera. The camera is solid. Rock solid so far.
There's loads on Amazon. You might need 2 to get the length you need.
Yes, I've been scouring the internet but can't find the same fittings that are on my TriPro which has a locking ring. I've tried another extension that I had lying around and that did not fit so not all cords are created equal.
I dont know that you can. you's be surprised how much you move your head around using a rear view mirror. You'll be very limited in what you'll see with one camera, if you force the camera thats 10 feet farther back to project it 1:1 in the "mirror".
