USB Socket for Passenger
Greg
5:24 PM
As this is still ongoing I thought I should start it's own thread and not clog up the "What did you do with your Grenadier today?" thread with updates
https://www.theineosforum.com/threa...your-grenadier-today.12411127/post-1333379389
I got the idea from something that Pedro has done. The usb socket seemed just the thing i was looking for
https://www.theineosforum.com/threa...your-grenadier-today.12411127/post-1333378146
Switch Boss - USB charger
Prototype_1
Rainy wet and humid Australia day, so....
First prototype of the usb socket done - sadly had to mount the socket upside down to get the wires running out the top.
I think there is enough gap to get wires between shiny bit and the panel. I will see once i can figure out how to take the shiny bit off.
But that will have to wait until the humidity drops under 90%
Prototype_2
Changed the back to re-route the wires to enable the socket writing to be up the correct way
Running the wires
Had a bit of a play this afternoon to see if it was possible to run the wires where i wanted them.
Much like Pedro I had no desire to be drilling holes in the dash.
However...
Looking at my options I decided that a couple of small holes (3mm wire size) in one of the unseen supporting brackets didn't really break the "no drilling holes" rule.
As you can see, just above the chrome border under the shiny strip.
There is quite a space behind to run the wires, which goes all the way down the panel as you can see in the second photo
It will require wires to be joined after threading through the holes - I was trying to keep the hole size to a minimum so cut the spade fittings off that came with the socket.
This may be a bit of a faff to do
Test Installation
Did a test fit to see if I liked it.
If I decide I don't like it, I can just remove it and it will look like it hasn't been touched.
Ignore the crap finish on the printed part as I was using one of my rejects as I didn't want to mess up a good one.
Ran the power to the switch across the gearbox tunnel floor to the driver's side fusebox under the ignition.
Used a handy earth on the way.
Positive came from FC23 in the fuse box under the ignition using a fuse tap.
The same way that plenty have done for their Wolfbox installs
I find the led lighting of the socket to be too bright - I should have gone for the one with no lights.
I opened it up to have a look and there are 4 leds on the circuit board which I will drop a dab of paint on one or two of them.
Next up will be to try and find matching grey filament or else give it a spray paint.
(Although true be told I will probably move on to the next project and not come back to it until my ocd bugs me enough)
What about trimming a piece of smoked plastic? Depending on the darkness it would substantially dim the light without eliminating it completely.
The dab of paint works well enough, but I will buy one without LEDs I think.
Can always find a use for usb sockets in future projects.
I'm hoping to do a similar install but on the side walls of the console. I noticed you were able to pry off the bottom panel of the footwell. Does the larger piece above that pry off as well? Or does that one take a whole can of worms to remove?
Love your work Greg. Very happy with mine being unlit. I love the no cables from the centre console more than anything.
I didn't give it much of a try. I will have a look at the online workshop manual when I fire up the computer tomorrow.
It may require some disassembly..
Yeah, I purchase an unlit one. I will fit it when the humidity drops a bit.
The manual says a bit more dismantling would be involved - Front panel and Glovebox.
But a bit of semi dismantling may work - let us know as it is something that is on my list for some other mods
4 screws
4 clips - forward facing so it pulls off towards the back.
there are
a couple of screws no the bottom with one hiding right up the back but reachable than just pops out
4 screws
Much appreciated! Am I the only one that doesn't have access to a manual???
