- Local time
- 11:23 AM
- Joined
- May 24, 2022
- Messages
- 353
They are Denali D3's with the Denali automotive wiring harness.Do tell about those lights!
Any feedback on wiring in the dash cam?Just put two USB ports in the Greny either side of the gearbox tunnel, wired in front and back dash cam and front fog lights
one of the dealers on the various FB groups posted that they take a feed for any dashcams from either one of the roof panel switches Labelled Int. 1 & 2. These are wired to switch the footwell power outlets and really close to where you want the camera and leave no bloody wires trailing across the dashboard from the internal USB ports.Any feedback on wiring in the dash cam?
me too. very interested in these and fittingsWhen are you fitting mine ? Looks great buddy.
Behind the plastic inner front wing on drivers side RHD vehicle is an unused factory grommet in the firewall, possibly for winch controlHow did you route through the firewall?
The dash cam has a feed directly to the aux battery so that the cameras work in parking mode. routed up the pillar under roof lining and out by the rear view mirror then the return to rear of the roof down the rear pillar and in the big door.Any feedback on wiring in the dash cam?
I prefer than that way on short range to light up the verges on our narrow country roads.
They look nice
There is not a lot of room between the bash plate and rad. The wiring harness came from the fog light makers.They look nice
How was the wiring and space around that area to do some DYI?
Oke nice that you got it done looks sleek!There is not a lot of room between the bash plate and rad. The wiring harness came from the fog light makers.
Pulled loads off the car today and can't find a "spare" gromet anywhere! Oh well, back to the drawing board. I've very tempted to put a new hole through the firewall with a new grommet.Behind the plastic inner front wing on drivers side RHD vehicle is an unused factory grommet in the firewall, possibly for winch control![]()
Where are you looking?Pulled loads off the car today and can't find a "spare" gromet anywhere! Oh well, back to the drawing board. I've very tempted to put a new hole through the firewall with a new grommet.
