Tyre Pressure Sensor Lost...
S52
10:53 PM
Peoples Republic of Kalifornia
Good afternoon.
Earlier this week on monday I took my Gren to my local tire shop to have a nail pulled and hole plugged from the left rear tire. The repair went well and I drove home without incident. Today was the first day since the repair I drove the truck and took it on my 120 mile round trip commute to work. On the drive home I got the amber TPMS light on the dash and the warning "Tyre Pressure Sensor Lost".
The car seems to have lost comm's with all 4 sensors. I am wondering if this could somehow be related to having the left rear tire removed and plugged? Just seems odd and very conincidental- but also doesnt make sense that all 4 sensors are now not communicating since only one wheel and tire were removed.
Anyone else experience this? Is it just a new "glitch" or should I take the Gren back to the tire shop to make sure they can verify the sensor didnt get forgotten or messed up?
Its a US spec May 2024 build Trialmaster with the 17" BFG All terrains if that matters. Also has not been in for the software update yet.
Thank you
Good afternoon.
Thank you
For whatever reason I lost all four TPMs readings for two days. This was a few months back and they came back on eventually and have been OK since. No idea why.
Reactions: S52
Interesting... Just seems like a very strange coincidence in my case. I've had my Gren for 10 months, logged about 5,000 miles and this happens the first drive after the wheel and tire were messed with... Hopefully it goes away I'll try driving it some more this weekend see if they come back online.
They will hopefully come back online for you. This has happened twice to me now. Both times they have come back on their own, after shutting it down for a few hours.
As for the tyre itself, a “patch” is considered a more permanent repair than a “plug”.
For clean, single hole on tread the plug works just fine. I have been at least ten times in situations where this has been the only feasible solution and none of these repairs have failed.
If there is a large crush or bruise or the leak is on the sidewall this doesn't work. I once helped a local friend who had a larger tyre bruise on his car (which according to the new style didn't even have a spare) I used three plugs and it continued to leak but after filling it he could make it to his home some 5 kilometers away.
Going off the topic a bit here... There is a whole British Standard ( BSAU159 ) that lays down what is and isn't ok. I am not a lawyer, inspire of working closely with lots of them, so maybe read the standard yourself.
But my takeaway is that plugs are definitely not ok, without a patch on the inside. Having said that, a plug to 'get home in limp mode' i would. It's sort of the old saying that some oil is better than no oil, and then the right oil is better than the wrong oil. If you have nothing else, a plug is available, use it. But don't be doing 100's of miles, by choice, at speed, without a more permanent fix.
A plug isn't something you want to live with, and even more so when running Light Truck weights.
I don’t want to play devils advocate here but I plugged a tyre that had a huge nail in it whilst in Namibia. That was getting on for 15k miles ago and still going strong. 💪
Update...
So I took it for a drive this morning. Initially the light was still on with the same message but after about a half mile drive it magically went away. All 4 sensors reading ok now.
Must have been a pesky "spurious electron". Hope it doesn't happen again otherwise it will be added to the list of annoyances.
-Christian
Only reason I jumped in and why I even know about the British Standard in question... I saw an L200 in my group use a plug about 25% off the tyre shoulder, have a major problem. People got hurt, insurance refused all compensation.
Bodge it, when needed, but get a fix asap.
Agreed on that mate. Anything off of the main tread is a very temp get me out of trouble fix.
