General Transmission Neutral Lever - Tool
samnt650
12:50 AM
New Jersey, USA
More of FYI - lever help put the transmission out of Park. This is for emergency use. Can only hope someone figure out how to turn it into an assessory that we can install on the truck....
Mentioned before. Crazy price.
You can put the vehicle TC in neutral as long as you can start the vehicle enough to get the trans in N. Carwash mode etc.
If you drive into a large puddle/river/sea without a snorkel and grenade the engine, well the above tool might help you if not your engine.. If you have a winch or someone close by has.
Or.....hear me out, you can use some wire or even zip ties. There is a lever on the side of the transmission that you simply pull down and the trans goes into neutral.
