Trailer bearings - in depth dive (trailer maintenance)
TheDocAUS
10:03 PM
Eromanga
A very interesting and informative video on trailer bearings and brakes:
View: https://youtu.be/WzEyUPEGvPY
We cover:
• How wheel bearings actually work
• Why incorrect adjustment destroys bearings
• How much grease is enough (and why more isn’t better)
• Electric vs hydraulic trailer brakes — pros and cons
• Common mistakes that cause brake failure
• What to check before towing any trailer
A farm trailer is one thing, your 2-3+ tonne home on wheels fanging along at 90-100km/ hr another.
I have 1.25T on each wheel ( single axle), so choice of wheel, tyre, bearing, bearing grease and pressure is critical. Let alone the brake system.
After each roadstop I place my hand on each hubcap as an easy temp check. Any significant differential I'd dig deeper.
Touch wood I haven't had an incident. Perish the thought.
I have also written a short guide on trailer checks in the field, although I now use an IR temp gun to check the hubs (or a Flir camera), Using the Flir thermal imager is like having Superman's x ray vision:
Putting the hand on the hub is also a good check for a brake sticking on ( especially with wire cable overrun brakes)
I have the IR gun tucked away with every other might need one day electronic testing tool in my Kings bag in the back, but the hand on hub seems to be pretty efficient - "pretty damn warm" ( OK) vs " "fark, that's too hot to get near, there's a problem" 😃.
I live in a world of acronyms and the young hospital residents serve me up new ones each month it seems!
Anyway the old 7"P"s = "Proper planning and preparation prevents piss poor performance" always guides my approach. And the old 3"P'"s we used to describe crumbly patients - "piss poor protoplasm" - can be used to prevent problems caused by supposedly rated Chinese alloy wheels and bearings, etc.
The back of the hand works well, it is all about any material differences in temperatures between each side that matters. If both sides are really hot, time to give it a rest.
I was shown how to do it on the The Kimberley Trip back in 2015. I did the first check under Barry's supervision at Drysdale River Station up the Kalumburu Road, which is off the Gibb River Road. Our version of the School of the Air.
We have stayed in contact after that trip and both hope to meet up again in The Kimberley later in 2026. I will see Barry in Warragul in Victoria in about 10 days. When the car and van go to Melbourne for PPF film.
The hub lesson was all driven by the Kimberley Carnage he and I witnessed. We sat in the Drysdale River Station camp area watching the next wounded warrior to come in. Plus what we saw when we went up to Mitchell Falls ourselves. The Mitchell Plateau Track is arguably the worst road in Australia:
THE KIMBERLY CARVES UP EVEN PREPARED TRAVELLERS
Those fancy plastic hub covers that many vans sport are a bearing health hazard in that they mask the heat.
The type of grease does matter. A proper lithium or clay (bentonite) based wheel bearing grease will be better then molybdenum disulphide grease the black stuff used in cv joints and plain bearings used on machinery pins. There are some good synthetic based greases around now. Molybdenum in grease comes as a percentage ie 1% 3% 5% and the higher the molybdenum content the more likely it is going to cause a wheel chocking effect on the roller elements in a high speed wheel bearing, especially in smaller bearings like the common Holden, or Ford bearings used in Australia.
It would be good to see these high priced caravans move to modern wheel bearing set ups like heavy trailers and truck axles even like the Ineos rear axle and use unitised pregreased bearings that can be fitted in the hub onto the spindle torqued and job done, no repacking grease or dealing with crap hub seals or setting preload.
For all the caravan and heavy towing gurus, assuming bearings and brakes are correctly adjusted and serviceable, what is the rule of thumb you go by on how hot is too hot when you checking wheel bearing, hub temperatures?
The new Patriot ST7 is using something different, fully sealed automotive bearings with disc brakes. The ST5 also has them.
View: https://youtu.be/BYGHG4hqyfY?t=1219
