Throwing 4 warning lights
armydiver
5:16 PM
Texas, USA
After about 5 to 7 min of highway driving I am getting the following warning lights.
1. Downhill assist
2. Uphill assist
3. No ECS
4. Reduced braking
Any idea what may be causing this? Any help is appreciated. TY
1. Downhill assist
2. Uphill assist
3. No ECS
4. Reduced braking
Check your battery voltage.
I have had the same warnings when battery charge below 20%
If i turn car off and don’t get out or open the door i have 4 warnings come up until next time i stop the car and open the door.
1 is power steering
2 is engine ECU
3 is transmission fault
Will have a look at what 4 is.
1 is power steering
2 is engine ECU
Engine check light will come on as a result of other faults - what does your display tell you when you check the recorded faults page?
1. Downhill assist
2. Uphill assist
3. No ECS
4. Reduced braking
Getting the same. Any updates?
Here are photos of 4 warnings. Car drives normally.
I solved my warning lights by simply adjusting the drag link to center the steering wheel. Took 2 minutes.
