More progress. Garmin PowerSwitch is in and functional. Front spots and chase lights are hot. Suma replacement mirrors installed, Tiny Rig device holder done.
First up - dual battery install using the RedArc BCDC Alpha 50. I had Warner do the install- really, really great work. The dealership was an absolute pleasure to do business with. They are 100% bought in, not just in it to move a unit, but to make sure the truck you get meets what you are looking for. Plenty of Grenadier stock parts but also lots of 3rd-party stock. 50+ trucks on the lot, including one on portals. And they have 3 Rebelle competitors that run out of their shop. Pretty awesome.
Also had the driveshaft serviced with Rezeppa replacement on the transfer case side. My plan is to just have it replaced every 10k miles when/until a real solution is released.
It did not- I specifically looked for one with no second battery and no high voltage switches. I’m doing all the secondary switching via Garmin PowerSwitch.I'm assuming it had the factory Ctek unit in there when you bought it?
I went through the passenger side grommet- left the Universal Solar Connectors in the engine compartment so I could disconnect the panels easily if I needed to work on the REDARC. Down the door sills, into the battery compartment. I used the extension cable that came with the kit. Female MC4 connector is the positive lead and the male connector is the negative. IRRC, I grounded the solar up front near where I came through the firewall.@Mr_Bacon_Jr Awesome rig, you've been busy.
I have the Leitner 3/4 rack. Originally thought the full length would make the Safari windows obsolete, but you can just move the cross members. Which I had to readjust anyway for starlink mounts and maxtraxx mounts, etc. I probably go full length if I was purchasing now.
I would also go the REDARC route vs. the CTEK120S / 250SE DC-to-DC charger route and you don't end up with a true "useable" house battery expanding the stock configuration that way.
Question for you @Mr_Bacon_Jr I have the Lensun hood solar panel in my garage but haven't yet installed. Did you run through the engine firewall grommet and then along the door sills to the 2nd row/REDARC? Curious how your routing option went...
How difficult is it to get the cargo area plastics off? I need to work of sound deadening.So I was a bit ambitious for this week's progress. I managed to get chase lights done, and the Klimat projects done. I have all the parts other than the Garmin PowerSwitch in hand. Garmin should land next week. Looking to get all the electrical wrapped by 4/15.
RH side is all metal clips, IRRC. pops right off- most difficult part was maneuvering the panel where it intersects the seat. Probably supposed to remove the seat to take it off and on- I did not.How difficult is it to get the cargo area plastics off? I need to work of sound deadening.
There must have been an issue with the jig that holds the upper RH leg- it's the one that is visibly off a degree or so. I am goiing to hit up Warner service and see if they have had the issue as well.I have that Letech ladder and same issue with the top right bolt. I pretty upset at myself as I got it in, but pretty sure majorly cross-threaded. I guess if I never take it off...no real issue.
I am much more happy with the Wavian Jerry Cans than with RotoPax.
Also got the Agile ditch light mounts hooked up. Very involved, but a super clean install. Not a fan of ditch lights mounted on the fender just kinda sticking up. These don't look 100% OEM, but as close as I was able to find on the market. You have to totally disassemble the doors, take off the mirrors, and run the cables through the flexible door conduits.
Also got the rock lights that PO installed connected to the Garmin PowerSwitch. They are pretty much a prime example of how not to wire stuff on your rig. KC Cyclones, with a homegrown mess of a wiring harness. I'll either rebuild the harness or just replace the whole thing with Baja rock lights.
All that is left now for electrical is to finish the USB install, clean up the rock lights, install Wolfbox (this weekend's project), and wire up the Starlink once the roof rack shows. ADGU drawer system should be ready in about 10 days, Letech sldiers in about the same timeframe. T minus 35 days to departure.
Will do for sure. Think I know how it will all go, but it always chages as you get into it!Be sure to post up how you go about the wiring and routing for the Wolfbox.
