Talking nonsense and general waffle
What are the benefits/disadvantages of this design. If it's such a good idea, why aren't all engines produced like this?
I'm asking as a complete novice so please explain a simple as possible, thanks.
No head gasket and better cooling to improve reliability. Mostly marine applications where engine reliability is key, especially in sailboats which have a single engine.
Reactions: Max
That's what my simple brain thought, so why not on all engines if it's more reliable, expense?
very expensive but I am guessing they are not produced to the same scale as car engines, whether that would make a big difference?
Weren't some cars built with obsoletion in mind so that the customer would have to keep coming back. The Mk1 Micra rings a bell with an 8 or 10 year lifespan? No point in having a super reliable engine if it doesn't long term create revenue. Once on this path there was no point in changing.
True.
But monobloc engines have been around for a long time , for various purposes. One imagines the latest iterations are superbly fit for purpose.
Cost, Steyr engines are pretty expensive. It is their monoblock design. The power output to displacement is a selling point. High boost with no head gasket issues at the combustion area. Steyr was involved in the development of BMW diesel engines.
The requirements of a marine diesel are distinctly different from a car engine. Often mechanical fuel injection, gear driven cams and fuel pumps, very narrow power/torque band. In-service life is typically several tens of thousands hours.
Got my new door locks and keys. Trying to add the little rubber ring ro stop the alarm going off but the tiny screw heads don't seem to fit anything. Either that or they are already partially rounded. I may have to drip a couple of drops of glue through the gaps, just not sure what to use as I don't want it to look at mess
Reactions: Max
I was at the annual Sunshine Coast Agricultural Show over the weekend and one of the exhibiters was a Transport Squadron from the Australian Defence Force. They have two camels for mascot duties which includes plenty on patting from the visiting public.
But the second big drawcard, for the "man and machine" brigade, which was supported by Dads, Mums and children, was a defence vehicle made in Australia named Hawkei [a death adder] and powered by a Steyr Diesel engine bolted to a ZF 8 speed auto gearbox...great choices.
One of the pics shows what's under the bonnet...yes it is the intercooler on the left with all the plumbing attached and the red 6 cylinder engine tucked in there. It's a huge area under there. The video explains a lot and that it is replacing our old G wagons that took over from the Defenders.
Plains Death Adder (Acanthophis hawkei)
iNaturalist
https://www.inaturalist.org › taxa › 93063-Acanthophis...
View attachment 7899952View attachment 7899953View attachment 7899951
13:19
YouTube · Talking Tactics with Mel Pikos
Inside the Hawkei: The Australian Army's Ultimate Off-Road ...
18 Mar 2025
Home - Steyr Motors AG
Steyr Motors AG
https://www.steyr-motors.com
Steyr Motors AG develops and produces high-performance diesel engines with the highest power density and durability for heavy-duty vehicles and boats.
Didnt you know, because its IFS it's fragile and unreliable. I read that on this forum, so it must be true. All IFS is inherently bad, and all SFA is good. The Ozzies should have read TheGrenadierForum. Now they made a piece of crap thats unfit for a fire road. Duh.
It's a tiny Torx bit - T6.
I had to buy a little driver set - I can't find the exact one I purchased, but it's a set like THIS.
This is the set I used with my original keys but none work on the new ones
Built in obsolescence. The Porteous Mill springs to mind. Almost every old Whisky Distillery uses a Porteous Mill. Built to last. Bomb proof. Porteous went out of business in the 60’s.
Now the idea of a Micra, …….disintegrating seems only fair. :-)
So the new keys are different?
I think they are. I was going to add a blocker for the emergency alarm but the key is raised more and blocks setting the alarm off by mistake.
The independent suspension is the strong area, stopping was the original weak point. Took them some time to sort the brakes out.
Reactions: Max
I had the opportunity to step on board the P&O containership, Arafura. It was powered from memory by a straight 8 diesel two stroke engine. It was started with a fine diesel fuel and once up and running it could be switched to virtually a crude oil. Nonsense or waffel, but I think I'm close to the money (y)
Reactions: CRH
Now that kind of engine would be perfect for an overlander for extreme places with dodgy fuel
Reactions: Max
