Tailgate folding camp table rattle
Bobs-dad
1:33 PM
England, UK
Hi Does anyone have an issue with the Ineos Tailgate foldable camp table rattle when you go over bumps? If so did you find a fix? I can’t seem to work out what part of it is rattling.
Yes I have the rattle. Solved it by cutting a piece of sleep mat foam to the size of the table and it sits inside the folded up table to stop rattling. It doubles up as a nice sitting pad too I guess!. Tried tightening all the fasteners but that didn't help.
If all the fasteners are tight and there is no play in the closed position. Then the next step is to use black anti rattle felt tape on certain inner sections of the arms which rattle against the table on bumps.
I have no rattles from my camping table even when off roading.
I'm looking to add the table to my grenadier. is it better to get an after market one or through the dealer?
If anyone has a link to a good after market tailgate table, i would appreciate it.
With Storage
Without Storage
they don't all rattle I have had long tern experience of 4 and no rattles over 5K on each
No rattles:
I went after market with the offering from @GPFACTOR and couldn’t be happier. It’s a high quality, made in the USA product.
Did the same, great (albeit EXPENSIVE) product. I use it all the time for so many things. It’s like a third hand . Highly recommended!
My one drove me nuts, I stuck two large foam sponges in, did not help. I stuck anti rattle tape around the arms and there is no longer any rattle whatsoever. Had never heard of anti rattle tape up to this point. No need to find a different table
Can you post a picture of the table with the tape visible around the arms, thanks.
I think it will be informative, aka I may need to do it and I can shamelessly copy your fix!
That is the anti rattle tape fitted, just apply wherever there is going to be a metal to metal interface, and like magic your noise has gone. Much more simple than many of the other proposals which don't work at best. Anti Rattle tape available on Amazon.
Anti rattle tape is what dealers use. I’ve used it in all situations, from behind gloves boxes to and door trims to fix rattles.
