Strange Squeaking Noise from Suspension – Anyone Else?
ilshamali
10:20 PM
Kuwait
Hey everyone,
I've had my Grenadier for about a month now, and I've noticed a strange squeaking noise—sounds a lot like a squeaky bed—whenever I go over a speed bump. I think it’s coming from the suspension.
I took it to the dealer, but they brushed it off and said there’s nothing wrong (without even checking properly). Has anyone else experienced this? Any ideas on what it could be?
Would appreciate any insights!
Update:
The dealer removed the suspension and re installed it as well sprayed wd40 lubricant and checked the bottle jack.
The squeaking noise still there and they will communicate with Ineos.
And attached video of the noise
  • VID-20250204-WA0011.mp4
    2.6 MB
If the jack is tight, this type of noise can also come from the heat shielding under the car. Once my shielding was adjusted the problem went away, it has not come back.
I also had the jack noise. More information here:
JACK NOISE
My Jack has caused me noise dramas. I took it out and put it in one of the drawers. The corrugations in Australia will cause all of us problems at some point.
Below is what I sent to my dealer who sent it to INEOS
GRENADIER MODEL
2-seater AU Spec Diesel Grenadier. Right hand drive car.
INTERMITTENT RATTLE
The irritating rattle started about 6 weeks after the car was driven from the dealership, having driven over 2,000 kilometres. No work had been done on the car around this time. It sounded like something was rattling inside onto the bodywork.
The rattle was intermittent and sounded like it was coming from the passenger’s footwell (RHD vehicle). Occasionally it sounded like it may be in the battery box, but no further back. Turning my ears towards the back of the car, several times, suggested it was not from the rear of the car.
There was no way to reliably reproduce the rattle when driving, it would come and go whenever. The rattle happened more often at low speeds (50kph or slower) than high speeds (rare), sometimes it happened when the car was angling to the left under brakes.
CAUSE
The Jack in the rear of the car. It is likely to have been a cause, but not necessarily the whole cause of the rattle.
THE HOW
The Grenadier comes with a standard bottle jack. The Jack is secured in the rear with a bolt and a strap. The bolt is finger tightened. Over time bumps/corrugations/vibrations caused the Jack’s extension screw to loosen and over time it unilaterally extended itself upwards. The metal U shaped saddle sits on top of the extension screw, after a time it had extended long enough to hit the metal bodywork above the Jack. The Jack was still secured by its strap, but the bolt was slightly loose. Therefore, intermittently the U-shaped saddle hit the metal work creating a rattle. It depended on the position of the saddle and the car movement - explaining why the rattle was intermittent.
It was a two-part fix, the nut holding the Jack onto the bracket also required a ¾ turn. The Jack was not that loose, but loose enough to allow the weighty Jack to move on the bracket (I suspect the bracket was also bending slightly back and forth under the Jack’s weight), allowing the extension screw and saddle to move upwards.
I think the slightly loose Jack bolt was the cause of the extension screw moving upwards and the moving Jack’s saddle hitting the metal.
THE RATTLE WAS TRANSMITTED THROUGH THE BODYWORK
With a 2-seater the sound was transmitted down into the front passenger’s footwell and sometimes into the battery box. The rattle never sounded like it originated from the rear Jack area. The rattle may manifest differently in a 5-seater.
This made finding the cause of the rattle frustratingly hard. It took a few weeks.
SOLUTION
I screwed the extension screw backdown onto the Jack, then taped the U shape saddle to the Jack, to stop it happening again. The Jack bolt was tightened. The rattle was mostly gone after that but has come back, making me think there was two different rattles at work.
I checked the Jack bolt a week later and the bolt was already loose. I removed the Jack and placed it in my drawers.
The following labelled Jack is close enough for illustrative purposes; however, the saddle is a slight U-shape on the Grenadier’s Jack. It was that U-shape saddle intermittently rubbing against the bodywork creating the rattle and the body of Jack moving on the bracket.
1715244866466-jpg.7856320
Hey everyone,
Good description of the noise. I have it also. I reckon it may be shocks compressing/extending. Maybe just one or maybe multiple.
That’s what I thought it was in my truck until I read his post. It doesn’t really bother me but I guess I’ll go check my jack😂😂
Update:
The dealer is claiming that the noise is normal
Update:
The noise is not normal, as you already know.
The below video is the squeaky noise
    2.6 MB
I have a sqeek or two in the back somewhere as well, sort of like old bed springs and happens on random road bumps not just larger ones.
But I haven’t been bothered to try to find it yet.
Job for another day I suppose.
Update:
The car remained at the dealership for three days last week to undergo a full inspection for Ineos. On the fourth day, they returned the car, stating that they were awaiting feedback from Ineos.
After 5 days, I received a call informing me that Ineos had requested additional inspections, which would take another three days. I am shocked by the poor service from both the dealership and Ineos.
Sounds like damper/shock squeak…but I would assume a mechanic would have figured that out by now if it was that obvious. 🤷🏻‍♂️
Mine was doing the same thing; I could hear it when going over the neighborhood speed bumps. The dealer ended up replacing two of the shocks (one front, one rear) to resolve it.
Update:
My car has been with the official dealership in Kuwait for about eight days for testing. They claimed to have shared the report with INEOS support and are now waiting for feedback—which has been the case for the last four weeks.
Despite their assurances of “daily follow-ups,” they still have no response.
Honestly, the Kuwait dealership has some of the worst customer service I’ve ever dealt with. For example, I ordered a cargo management solution, and they initially told me it would arrive in four weeks. Now, after six weeks, it’s still not here.
Has anyone else experienced similar delays? How long did it take for INEOS support to respond in your case?
Update:
I've the same squeaking noise in my grenadier, please keep me updated .
In my case, squeaking started at around 3.000 km and got worse (now at 6.000 km). Noise is triggered by pitch/roll, e.g., when accelerating and braking, cornering, driving over small bumps, getting in and out of the car. Difficult to locate - front and rear, but more at the rear. Left and right, but more in the middle. Zero noise only during heavy rain. No ride/performance/comfort issues thus far other than nerve-wracking noise. No modifcations, no offroad. Same symptom? Dealer could not reproduce the noise on other cars on his lot. IA customer support elevated it to their technical team, no response ever since. Showed it to a mechanic who suspected that some part or parts that are supposed to be lubricated were installed „dry“ (faulty supplied parts or faulty installation) and needed to be completely exchanged (dampers, whatever - until noise disappears). Cause? Cure?
  • 20250324_184314~2.mov
    6.6 MB
Have they adjusted the heat shields under the car? When my heat shields were adjusted the noise went away and has stayed away.
Thank you very much for this - any hint is greatly appreciated, and your special expertise is clearly unrivaled. It is a petrol Quartermaster, should it make a difference. At its face, the whole underbody is very well designed and flawlessly executed, including heat shields. Will get under the truck tomorrow and look at the shields closer - to this end, what exactly do you mean by „adjusted“ if I may?
The dealer told me a few cars had the issue. Hopefully it works for you, worth a try.
