Soft Elements Underside
trobex
1:36 PM
Australia
Just looking at the Production model from the Spanish video front springs area: the braid will be ok generally, but to me is there a few soft plastic runs here... are we thinking these will remain save for the life of the vehicle? I am thinking small branches/limbs and large gibbers coming up from rougher terrain with direct LOS from ground to impact zones. Am I just overthinking.
if you mean the brake line, that's a steel braided line, what alternatives would there be?
Behind that are two lines - both look exposed - looked under my Triton and I dont have them! Just seems to be an odd location as exposed to LOS attacked from ground up. Only a though. Brake line is braided and good.
Pad wear sensor and wheel speed sensor cables?
Likely - but not 100% sure. Tyre pressure??? Anyway, plastic and in strike zone IMO. Maybe the 1st drivers to receive can check, and look a little deeper for us?
My 05 TRITON has not very much gone on there... like... a spring and shock. I don't even know if it has front brakes - those that work anyway!
Brake lines are wear items. Braided lines give a false sense of security as you cannot assess the hardening and cracking of the rubber.
The braiding can reduce abrasion etc but don't assume they will last the vehicle's lifetime. Maybe 10 years.
Goodridge offer a lifetime warranty, although the wording may be a little off:
Yeah, brake lines are ok. Wear items front of house might need a little love. Have to see what this looks like when it arrives. What I saw from the video look to be a pretty good quality underside...
I have only ever had one problem with a line, fuel line crack in a car that was 12 years old at the time.
