Soap draining to passenger floorboard!
DarrenM
1:15 AM
Frisco TX, USA
Ran my Grenny through the car wash today… photo shows where soap started draining down from passenger side dash near floorboard.
Can anyone shed any light on this for me?
Never once saw this during multiple car washes. But this year I am only hand washing - even though I used “touchless washes,” the pressure is pretty high and they do a crappy job. I think that’s why I had to redo the nose wrap and Exoshield- and it always made my door buttons stick.
Isn't there a open vent above the passenger side that is open unless you have recirculation on. There was a recall for some that were missing a cover so when it rained and you were driving, water would come in. Could this be the source of issues
I bet this is it. Without soap... I likely would have never noticed it as the carpet is black and it wasn't a tremendous amount of water. Thanks for you comment.
I just took mine in for warranty and 1 year maintenance. I had below list to have them fix.
1. Door footbath problem.
2. Safari windows leaking onto the dash.
3. Small water puddle in center of front passenger floor. (seems to be your issue).
4. Water intrusion at the top of the large rear door. Water would get past a split seal at top of rear cargo door and run down the inside glass.
5. Door handle recall if parts available.
6. Windshield replacement. Glad I bought the glass warranty.
They fixed all, and knew about everyone except the rear door water problem. But they replaced all the seals except for the front doors,(they ran out of door seals). Go figure, that was the main one I wanted fixed. Just waiting for seals to be re-stocked.
So the water in the front floorboard is from the fresh air vent and is a known issue. They should be able to get you fixed up. Next hard rain after the front door seals are replaced will be the test for all water leaks. Fun times fellas!
Thanks Big. I'm going to print this and take it to my dealer (which is Sewell in Dallas) One year maintenance in Dallas is 840 bucks for an oil change and the differential fluid change. I would do it myself but I can't reset the super loud Bong every time I start it up!
Yep, the $840 does suck. I only have 2700mi on it.:confused:
Sewell is my dealer as well. Brandon will get you fixed up.
Edit to add: Just double checked receipt. They found an fixed 2 problems for the water in the floorboard.
1: Water defector strips to cowl trim.
2: Fresh air intake.
So 2 points they need to address.
Thanks again Big. I see you're in McKinney. I'm in Frisco. Eldorado and Legacy at Newman Village. I'll be sure and tell Brandon... I sure appreciate your insight. :)
