Build Thread Snuffleupagus
KristinaM
2:45 PM
Oregon
Introduced here:
https://www.theineosforum.com/threa...your-grenadier-today.12411127/post-1333369436
2024 ( Petrol ) Ineos Trialmaster
We’ve added the following components over the last year ( most of which occurred over the last few weeks ):
Alu-Cab Silenus RTT - replaced the roof grab rails with black ones from GrenadierUSA
Alu-Cab Shower Cube
Alu-Cab 270 Shadow Awning
Alu-Cab Molle Panels for Joolca ( HOTTAP pumped hot / cold ) water system,
Propex ( PS2000 Portable ) heater, and VAAST 18L water tank
ROAMRest custom mattress for the Silenus RTT - HEST stuff for bedding since they’re close to us
300W Solar Array ( 6 x 50W Sunflare XPLOR BLOX panels )
Buzz Overland Big Brake Kit ( red of course ) along with Buzz door steps
REDARC BCDC ALPHA50 12V 50A DC Battery Charger
REDARC ALPHA150 12V 150AH Lithium ( Auxiliary ) Battery
LRA ( Brown Davis ) Auxiliary Fuel Tank
Braid Fullrace T Dakar Wheels with ( Agile Offroad ) Apex RPV + TPMS brackets
Victron Orion-Tr 12V / 24V 5A Isolated DC DC Converter - used for Starlink Mini via external mini-Anderson
LETECH Multi-Function rear ladder ( we’ve put another 18L LIFESAVER Jerry for water in this location )
Ineos ( OEM ) Roo Bar
Wolfbox G900Pro rear view mirror with 67Designs mount since the rear is packed with gear
Ineos ( OEM ) front and rear “black” springs
GrenadierUSA machined center console ( looks cool )
GP Factor folding tailgate table and Starlink Mini mount - powered through external mini-Anderson
port on the driver’s side ( seen below )
Agile Offroad’s ARB Onboard ( brushed single compressor ) Air Kit ( under rear seat - plumbed into the back )
Abenteuer 4x4 Rock Sliders
REDARC Tow-Pro EBC ( mounted under rear bench seat with dial adjustment in center console
Guzzle H20 ( Stream ) water purifier
GrenX Aluminum Snorkel System with Sealed Airbox ( OEM styled variant )
Other bits:
Rosen visors and SUMA ( convex ) mirrors from Owl - wanted these for the Molle panels.
Black Sheep Innovations display sun visor for the head unit - Seems to help minimize the glare a bit.
Agile Offroad ( Baja Designs ) offroad grill lights - AUX1 with dimmer support
Baja Designs ( passenger / driver ) scene lights ( 2 x S2 Sport )- Switched externally since these
are powered through roof mounted DTPs
Baja Designs reverse lights ( 2 x S2 Sport - attached via Leitner Designs chase light brackets )
GME GMRS radio setup with KAON LHS ( driver side ) antenna mount
Forgot to mention:
Goose Gear CampKitchen and rear plate system ( driver side ) - We’re running a National Luna Legacy Smart 50L
fridge / freezer and Cook Partner 22” ( 2 burner ) stove within the CampKitchen module.
A few bits from the GrenadierWorks store too ( the rear door handle is awesome )
No doubt other stuff I’ve failed to mention…
Introduced here:
Alu-Cab Silenus RTT
Alu-Cab Shower Cube
Alu-Cab Molle Panels for Joolca ( pumped hot / cold ) water system, Propex ( PS2000 Portable ) heater,
Buzz Overland BBK along with Buzz door steps
LRA Auxiliary Fuel Tank
Victron Orion-Tr 12V / 24V 5A Isolated DC DC Converter ( used for Starlink Mini )
LETECH Multi-Function rear ladder ( we’ve put another 18L Jerry for water in this location )
REDARC Tow-Pro EBC
Other bits:
Agile Offroad ( Baja Designs ) grill lights - AUX1 with dimmer support
Baja Designs scene ( passenger / driver ) scene lights - Switched externally since these are roof mounted DTPs
Brilliant. Let’s see some pictures for inspiration 👍🏼
Thanks. I have quite a few shoddy images of the install process in action:
The additional mass is under ~700 lbs for this build - including supplies. I’d consider that pretty good. We’re using this for longer term ( multi-month / year ) international travel so it’s not really intended to be a rock or mall crawler. :-)
Part II:
So it looks like our GrenX sealed snorkel and airbox system will arrive tomorrow so we’re ( finally ) on track to schedule snorkel, airbox / pod filter, LRA ( Brown Davis ) Auxiliary tank, and REDARC electronic brake controller installation. This just about completes the build.
