roof rack as an accessory from vickywoods
Pat-Ard
Global Grenadier #00520
9:42 PM
I think they all already know. Nakatanenga will have a cargo bear for the Grenni, too. I think they are all still under NDA.
8:42 PM
The most interesting is the fixing on the front centre of the roof ~ is this the EXT 2 wiring socket for the LED light bar?
Edit: or they've based there photos/renderings on old images ~ now I've checked, the item was on early prototypes but then disappeared...
8:42 PM
Well it's certainly disappeared on more recent prototypes, so a GPS antenna would fit the bill. 👍
ADVAW8S
Global Grenadier 0044
12:42 PM
Kirkland, WA, USA
One thing I will add, it looks like you can use the safari windows with this rack set up
8:42 PM
That puzzles me with regard to the Ineos/Rhino rack arrangement. Obviously, there's a requirement to get the rack as low as possible (within reason) and also have the safari windows open enough to obtain the required degree of ventilation; but once the conflict came to light I'd have expected something to be done to resolve it.
Does the arrangement of the catches look like it should really be an issue to resolve?
So I'm left with going back to the statement that the Rhino rack and safari windows are in some way incompatible. Is this actually true and if so in exactly what manner?
Francois
9:42 PM
South Africa, Cape town
The agent of IG here in South Africa has confirmed that the windows could be opened with the roof rack fixed.
das mo
9:42 PM
Info I got yesterday is that safari windows cannot be openend with Rhino on. Maybe few cm, but the will pust against the rack. The one posted above seems to provide more room. As the Rhino ones comes at 60kg, I would very much appreciate a lighter one coming up.
