Rok_Dr’s Exceedingly Unofficial Owner’s Manual Supplement
I've just published an update of of the Rok_Dr Manual. Changes since the last edition include:
• Misc typo and English corrections.
• Appendices renumbered.
• New Section 7 Vehicle Recalls.
• Section 8 Overhead Switch Panel updated.
• Section 12.1 Brake Fluid Specification and volume updated.
• New Section 16.9 Transfer Case Oil Change
• New Section 16.10 Transfer Case Linkage Adjustment
• Section 17.14 Seat Back Pockets updated.
• New Section 17.15 HVAC System Operation.
• Section 18.1 Rewritten and figures updated.
• Section 21.1 Ineos Documents, Links and Resources updated.
• Table 4 - High Load Auxiliary Switch Panel Functions updated.
• Table 9 - Fuse Types updated.
• Table 12 - Filter, Belt & Other Part Numbers. Brembo rear brake part no corrected. Front and rear hub nuts added.
• Table 15 - Tyre and Wheel Rim Specifications updated with Rim PCD.
• New Appendix 2 – ESC – Function Matrix INEOS Grenadier.
• Appendix 4 - Trailer Electrical Connector Schematics. 13 pin schematic mirror image error corrected.
• Update Appendix 8 - Vehicle Specification Codes.
Download using the updated link in post #1. If you have any problems downloading please let me know.
NOTE: While you are welcome to share, please do NOT share the actual document or google drive link. Rather share the link to this thread or the first post. That way others will always be access to the latest version. There have been couple of instances recently where outdated editions of the document were posted elsewhere on social media.
Also let me know if you find any errors or typos. Because of this if you are in the habit of rushing out and printing a copy I'd suggest holding off for a week or so in case I have to do a quick update.
Thank you all for your positive feed back, contributions and suggestions, it's really appreciated.
Enjoy!
Cheers
Steve
I've just published a very small but important update of of the Rok_Dr Manual (V12a). The only significant change is to up date the torque values for the suspension control arms to reflect the change in the online Ineos workshop manual and note their single use. Thank you @Glen for picking this up and all your efforts in engaging with Ineos support to try and resolve the inconsistencies of their torque specification for these bolts.
If you have already printed the guide out its probably not worth doing it again for this change. just make a written note against the table..
Cheers
Steve
