Rok_Dr’s Exceedingly Unofficial Owner’s Manual Supplement
Just for info, if you don't have access to the Grenadier wiring diagrams.:rolleyes:
an MY23 May, Fieldmaster
6 pin DT plug Headlight wiring guide.
Pin Wire Colour Function
1 Black Earth
2 White/ Blue Head Light
3 Brown / Red Main Beam
4 Blue/ White Daytime Running Lamp
5 Brown / White Side Lights
6 Yellow/ Brown Indicator
G
As they say its been a while since drinks and I've finally found some spare time to update the manual. Also as the manual matures new content is increasingly harder to find and so updates are happening less often.
Changes since the last edition include:
  • Miscellaneous small updates, corrections and reformatting
  • Updates to Table 2 and Table 3
  • New Section 4 Ineos Manuals
  • New Section 10.4 Deutsch Connectors
  • Section 10.7 Add general torque value links
  • Table 15 - Grenadier Fastener Types updated
  • Table 9 - Filter, Belt & Other Part Numbers updated
  • Section 13.2 AdBlue update with fluid shelf-life commentary
  • New Section 14.8 Front and Rear Differential Oil Change
  • New Section 15 Tips and Tricks, including
    • Sect 15.2 eCall reset Procedure
    • Sect 15.3 Disabling the Alarm Tilt Sensor
    • Sect 15.5 Sticky NATO Plug Cap
    • Sect 15.6 Ineos Red Winch Single Line Pull Loads
    • Sect 15.7 Retrofitting an Ineos Red Winch
    • Sect 15.8 Spare Key Blade
  • Tyre rotation and Long Term vehicle storage moved from Maintenance to Tips and Tricks.
  • Sect 18.2 Other Links and Resources updated with links to general bolt torque values
  • Appendix 1, add winch load pull table.
  • Update Appendix 7 - Vehicle Specification Codes . Added new MY26 codes
Download using the updated link in post #1. If you have any problems downloading please let me know.
If you find any errors or typos please let me know. Because of this if you are in the habit of rushing out and printing a copy I'd suggest holding off for a week or so in case I have to do a quick update.
Thank you all for your positive feed back, contributions and suggestions, it's really appreciated.
Enjoy!
Steve
If you find any errors or typos please let me know. because of this if you are in the habit of rushing out and printing a copy I'd suggest holding off for a week or so in case I have to a quick update.
Enjoy!
Steve
Thank you for your hard work keeping this up to date and adding to it.
Many moons ago I found myself working on a defender quite a bit and I collated some existing resources into a single spreadsheet like so:
Now that we have access to the dealer workshop manual, something like this might be possible.
Good idea!
I just made a cursory pass at uploading this to lulu.com for printing - it seems to be choking on page layout, specifically it requires that all pages be the same size and orientation. @Rok_Dr would you be willing to make them all uniform for commercial printing?
Hi Adam
Thanks for the feedback. That's the first time I've heard of the problem as Adobe and most other PDF software can automatically rotate pages when printing, while still having the pages in the correct orientation for reading on screen. Is it just Lulu problem? Out of curiosity I'll ask my printer who does online work, if its a widespread issue, when I next see them.
All pages in the manual are A4 in size so its likely the 2 landscape appendices (1 & 2) are tripping things up. I could rotate those appendices but then it means managing 2 separate versions which I'm loath to do at present.
Steve
Hi Adam
Steve
I'm not sure - I just tried dropping it into lulu today on a whim. There might be another service online where it works - I'm just kind of thinking ahead to the concept of producing a printed field manual of some sort.
Thanks for the great work!
Time for yet another update. Changes since the last edition include:
  • Typo corrections.
  • Figure 6 correction.
  • New Section 6 Vehicle VIN Number.
  • New Section 10.1 Battery.
  • Section 11.7 Update torque values
  • Update Section 15.8 Front and Rear Differential Oil Change.
  • Update Sect 15.12 Exterior Parts Removal.
  • Table 17 - Grenadier Fastener Types updated.
  • Hiding Centre Screen Alerts moved to Sect 16.1.
  • New Section 18 Remote Area Travel
  • New Section 20.2 The @TheDocAUS Lists.
  • Appendix 2 - Fuse & Relay Listing updated.
  • Appendix 8 - Daily Pre-start Check List.
  • Appendix 9 – Emergency Details Glovebox Form.
  • Appendix 10 – Australian UHF Frequencies
Enjoy!
Steve
This is a BIG, BIG update.
Thanks for all the work, Steve. Plus input from @globalgregors and @Logsplitter
Owners take note of new appendixes 8, 9 and 10 and the new section 18 on remote travel.
Owners outside Australia might like to post a link to the CB or UHF frequencies used in your country (AU channels now in Appendix 10.
This a valuable resource for owners, so download it and use it. :)
Thanks for all the work, Steve. Plus input for @globalgregors and @Logsplitter
@Stu_Barnes @Krabby
For general information there was some new CB, FM, UHF and HF radio updates from the Australian regulators in the last month.
@Stu_Barnes @Krabby
Thank you for your kind words Michael, it’s always appreciated. Ditto your continued valuable input.
I’m more than happy to add additional CB frequency tables for other countries, but please if you send me links, also let me know if there are any channels that are reserved or have specific uses such as channel 40 in Oz.
Steve
Thanks @NQ94 can you forward me links or more specifics?
Steve
