Rock Sliders
ocmcqurus
9:08 AM
huntington beach
I had the OEM steps on my 1924 that I have removed. I wanted to get the Agile sliders but I didn’t love the way they were mounted. I really want to use the factory mounts by the frame because they look so weird with nothing mounted to them. I am also looking for a slider/step option. Look for some friendly advice with photos.
i am very happy with my Dissent sliders. They fit the factory mounts and sit tight to the body but can act as step as well. installation took about 3 hours with a friend.
I have the Dissent sliders as well.Take a look at the Metal Cloak sliders. Similar to the Dissent.
These were at the top of my list.
Sliders need to tick 3 boxes in my mind.
In no specific order, it needs to enhance the looks of the truck (look proportionally good), protect the truck, and have added functions like a step or jacking point.
The sliders of Buzz Overland and Agile are the two I'd consider. Both look ggod.
The BO ones make a lot of sense to me because of the practicality they offer by providing a step and jacking points.
The AO sit perfectly well and high up on the other hand, which is another consideration.
AO sliders mount to the body of the truck. They do not serve as jacking points.
I would argue they serve as poor protection.
Dissent sliders here. Love them.
Buzz Overland rock sliders are what I’m going to add
They do serve as jacking points. And they are a far better body protection than none.
SafariGard sliders mounted to the body of a Disco or Classic, which was made out of paper-thin metal. It took some beating for the sliders to move enough to cause problems.
Keep in mind that ALL frame-mounted sliders have to have a lever arm from the nearest body mount to the outside of the slider. And, unlike body-mounted sliders, the brackets for frame-mounted sliders are typically short.
I challenge you to fi
I challenge you to find any language on their site that claims this slider can be used to jack up the vehicle.
Zero mention
Yes body mounted slider is better than nothing. However given the optionality of well made frame mounted sliders and this body mounted, there is very little value prop for the body mounted slider.
Thank you, I have looked at these too. Do you have any photos of them on your rig?
There's a couple variants of white knuckle -- more discussion on some other threads. I put these on, which are the no bump-out version of the white knuckle. Search "rocksliders" as one word for even more results.
Zero mention
Honestly... The only time I had apply a jack to a rock slider is to bend down a Safari Gard slider on a friend's Disco 1.
I mean I don’t jack up the vehicle via slider either .. but whether it serves as a jack point is a strong signal to the slider’s design, strength and protection quality.
Any slider that can function as a jack point is obviously strong enough to hold the vehicle on a rock, without damage to the vehicle
If a slider is not marketed as a jack point. It’s an automatic red flag no?
AO doesn’t advertise its body mounted slider as a jack point
