Reardoor wont open
As hoped, we were blessed by the chaotic neutral intermittent fault. Open sesame!
Have installed a failsafe of sorts:
I love your trick, will implement it too! Why? Because I had rear door problems too. In my case, and after some trial and error it got solved by spraying some lubricant in the main and upper latch of the door.
Thanks, @Jean Mercier - this appears to have also improved ours.
Was driving towards Ararat and on the Ballarat by pass all of a sudden back doors open warning came on. When i pulled up back doors were open. Have closed them again and the button is very hard to push in. Will try later to open them.
After about 1000km on very dusty roads i had the issue where i could not press the rear door button to open the door. I was able to open the door from the inside. Relubing the lock mechanism solved the issue.
Further update to the rear door issue. It seems to be an electrical problem. When it doesn’t open now i grab the remote and stand at the rear door and just lock & unlock till i hear a definite click at the rear door.
I had exactly the same problem, and I used your trick too: "locking and unlocking until I heard the trick", but as mentioned previously in this thread, after cleaning and spraying some lubricant in the upper and lower latch the problem is solved! Therefore I think it is rather mechanical, and not electrical.
