Rear Locker Failure Update
Mountain4x4
12:47 AM
Albuquerque, NM, USA
Back from the dealer last night, new rear diff installed. Still no technical conclusions other then a mechanical failure. However, after the dealership had the first road lock they were able to repeat it consistently, so the problem would have grown worse. A few thoughts;
1. Be sure to know the warning signs as this could be dangerous. Extremely long delays getting the rear locker out. Say 10 minutes or more off road, rolling backwards, taking it out of center lock does not seem to get it done. And and chirp of tires on road especially with dash lights on a turn.
2. yes, its rare. HOWEVER, 2 more have cropped up since mine in October. 1 other in Colorado and 1 in Illinois. So while not wide spread yet, we now have 3.
3. Cost according to dealer to replace complete rear end 14,780.00. However parts are available to fix the mechanism, but the dealers have no technical direction yet and Ineos needs to understand the problem.
4. Initially only a little metal in diff, but dealer did another diff fluid change while diagnosing and the fluid became dirty right away. So again, verifies a bigger issue was coming.
5. Diff came from Belgium, total time from diagnosis, claim approval and fix about 6 weeks.
Currently this is a rare occurrence and we have no idea where it will go. So just be aware. If it becomes widespread it will have to be a safety recall like the drive shaft issue will have to be.
My Grenadier has been at my dealer for 2+ weeks now with the exact same problem. It is a 2024 with 23,000 miles and has been dealer serviced at 10,000 and 22,000 miles.
The dealer reported that they have been able to replicate that the rear diff lock is engaging randomly. The dealer reported this to INEOS and confirmed to them that the rear diff fluid was replaced at 10,000 miles as required.
The last dealer update is that they are waiting on direction from INEOS. It sounds like replacing the whole rear end assembly is the fix.
This issue also started with a delayed light off unlock confirmation and progressed to random rear diff locking and all the associated warning lights. The first few times the rear diff would disengage after a couple miles but quickly progressed to more consistent and prolonged locking. I then parked it and arranged thru INEOS roadside assistance to have it hauled to the dealer.
I will contact the dealer Monday and ask about a complete rear end replacement.
Uh oh, your not Illinois or Colorado...so we have a 4th. Still a small sampling. At some point they will start repairing these to save money. Mine was supposed to be the one to study, they sure don't need 4. Funny though other failures seem to be more consistent then mine was. Not sure if smashing it around off road makes the difference, or more likely I dodged a bullet driving it 800 plus miles after the problem.
Mine is currently at the dealer, (2 weeks). Oddly we both came to the conclusion it was the center diff that was locking up. It happens in the cold, and only in the first mile, after that it frees up. We are thinking its the center, because, I've had both front and rear tires chirp, and if I hit the circular bridge ramp first thing in the morning, the truck would detect the wheel speed as an issue (slide) and interrupt power. I have not heard from RDS in a week, they were waiting on INEOS input. Maybe its the rear... I guess we shall see.
I'll add, This hasn't been off road. I've been waiting on a driveshaft solution and have other options. As such, I've only worked the case and lockers twice on gravel to make sure they work.
I bet its the rear diff, geesh seems like 25K+ is the point at which this starts. Where as the front Driveshaft will easily drop long before. I guess this is now the official rear locker failure thread. :( I am trying to wrap my head around the Cold vs Warm issue. My experience was warm, but my dealer says they replicated it ice cold as well. And it was pretty cold when it would not unlock in Moab in a shop. This starts to blow apart my theory of tension built up in low range or locked mode off road. It appears something can fail under most any condition and begin to randomly lock the rear. The closest thing I can think of was a LSD in a 1990s Montero Sport was recalled because they had been made a little too tight, and on the verge of full lock up. If this does become a recall, I bet they can install a replacement, re-designed mechanism from Carraro, or at worst a new drop in 3rd member. These have to be fun phone calls with suppliers...Hey Carraro what gives...Hey BMW what's up with those cheesy plastic tanks....Yo Dana that shaft angle you said was fine.
Has anyone checked how this is happening?
What I mean is, as fare as I know the locker is sprung to the unlocked position, and locked with electro magnets, so a power failure should result in a locker that won’t lock. Rather than stuck locked.
It can get stuck locked if it has been crash locked and the locking pins get galled up but that shouldn’t cause random locking events.
So in order for it to lock randomly either the spring has broken and the locking plate is free to move around at random. Or the car’s brain is sending a signal to the locker and it is locking electronically….
Has anyone tested the wires for a signal in these permanently locked cars? Or tried disconnecting the wires to see if they unlock?
According to Hans Peter, he felt it was a spring problem. Yes, it will lock with the harness disconnected. I did not test it because it was obviously not electrical, but Red Noland did. It is definitely a failure in the locking mechanism.
My dealer reports that INEOS asked them to test with the actuator wiring unplugged and the diff lock is still engaging.
These episodes illustrate a failure mode consideration for all of us: When making the decision to lock any differential, remember that the ability to later drive out on ‘high traction surfaces’ (roads) will be severely limited if the differential cannot be unlocked…
Well, I had an email from the dealer and they believe it’s the rear and not the case. It’s at Ineos for input.
He did mention he was happy I had the rear differential service there, as they came back want proof the 12k diff service was performed, and they could forward it.
I said it before when I drove the 4.5 hrs to get it done, but I think it’s a good time investment to get that phawkin service done at a dealer so it’s definitive. It’s clear right now I’d be gathering proof and hoping it’s good enough for the people losing money, or I’d be shit out of luck. Best day trip I ever made.
Yet another mystery, E lockers have been around for donkeys and tested by huge amounts of 4wders
How has Ineos and Cararro managed to screw the pooch on this one?
Also going straight to the default of was the service done is looking for a excuse for an out IMO
No other manufacturer specifies a diff oil change at first service which to me indicates they are well aware of a design issue
It's unfortunate. I'll bet IA are just as unhappy as everyone one else. It's not like they set out to have component failures early. But while you're swinging your tar brush around don't forget to mention Eaton Industries (Korea). They might have a role in this.
"No other manufacturer" That's a big claim. Have you checked all of them?
As soon as I got a whiff of the possibility of diff problems I had the oil changed. Earlyish at15k km, but I do not want to be in that pelican colony, surrounded by enormous bills.
That may be simple. Eaton never assumed or maybe even considered the lockers would end up in rear ends that used cast gears. Those gears require a break in, which results in metal corruption of the fluid. Which in turn affects??? The wiring? The viscosity? The surfaces of the locker? No idea, and nothing we can prove or test.
Seems odd that this doesn’t crop up until at or after the first fluid change. My first instance was at about 13deg/f last year right before the 12k mile service, and nothing could be replicated. I’m at 22k+ and it is now every morning below 35. They likely thought I did’t know what I was doing Or talking about when I said the rear differential appeared to have locked and pushed me into the oncoming turning lane. I sure would have thought I fucked up and was projecting. I almost didn’t believe me. On two of my occasions, there could have been several damage or injury if the road was busier.
Wild guess.
