Americas Question for GP Factor table owners
cdsvt
12:11 PM
Vermont, USA
I picked up a used GP Factor table (the prior owner upgraded to the one with the cubby). I installed it, and it is terrific.
However, the bamboo table doesn't fit in the slot in the stainless table. It can jam part way in (4" maybe), but it is an interference fit and cant go any further.
Has anyone else seen this, and if so, what did you do?
The only thing I can think of is to carefully sand down the edge to let it fit, while being careful to not go too far so it becomes a sloppy fit.
Any other ideas?
Footnote: the guy that I got it from was super nice and has an amazingly built trialmaster. He told me about the wood table fit issue, so I knew what I was getting into.
Measure the table thickness, then measure the space in the stainless guides. Maybe you can open the gap a little so the table slides freely.
The cutting board being a natural material can change shape especially with humidity. Oddly, I had the opposite problem with the cutting board banging around and developed a solution to hold it in place. One thing to check is if your board has a slight bow or curve to it. If you are trying to slide it into the table top with the crown facing the underside of the table the board can jamb or be tight. Try flipping the cutting board around and see if it goes in any easier.
I routinely flip the board around about once a month to keep it from getting out of shape or used to being stored in one position for too long.
Any other ideas?
Sanding it down carefully is the standard fix for that issue. Others have done the same. Go slow and check the fit often.
I see that you got it to fixed it by sanding down the board to make things fit, and that works. But I’m afraid if you flip the board upside-down in the table as it warps for better sliding (which I did pre butcher block oil), or to get a clean side when cook prepping ,which I do a bunch, the sanded edge will only be smooth in the one orientation. Mine too was stiff when I got it, even though new, so I’ve been tuning it for a year.
If it helps you or someone else, here are my solutions for the stiff board/table interface, and for the warping, and for over-insertion issues. They are super easy fixes that take longer to find the tools, than to actually do .
First , de- burr the tables’s lips/edges with a small knife sharpening stone.
Then, slide the board in as far as it goes with light pressure. Put 2 small to medium adjustable wrenches tight on the lip about an inch apart at the tight spot.
Now spread the lip apart a TINY BIT, test and retry until perfect. It’s easy to over-do, and harder to tighten than loosen. Repeat as necessary as you slide the board further in with light pressure, until the board goes all the way through, with just light pressure.
Now it’ll be back to stock. But stock needs help. Because now the board will go easily alll the way through, past the table edge and under the hinge, now interfering with putting the table up.
To prevent this, get 2 little pieces of adhesive loop (as in Velcro) material and place them where they just begin engage your board as it comes to centered on the table.
Now your board will stop where it should, and not as an extra benefit, not rattle on heavy washboards.
To keep the humidity warping at bay, take out the board and put it in the sink (this is messy). Heavily coat the cutting board in butcher block oil overnight. Then, a couple of days later, after the oil is really soaked in and the board is dry to the touch, get a little beeswax bar and dry rub that all over the surface and on the table’s slots/lips. Not only will the cutting board not stain from food, it will clean up a whole lot easier and it will slide in and out of the table like ‘butta’.
I hope these extra ideas work for you as well as they have for me . I love this table, and with the few tuning steps, it’s one of my favorite mods.
Any other ideas?
Mine was the same way. I thought over time it would fit but it didn't change over a couple months. I pulled it out one day with difficulty, wiped the oil that I was given with the table. I thought this would make the wood swell up and I would have to sand it down but instead it shrunk the wood to the point my table was sliding around now in the metal slots. I just had to make the modification with 4 thumb screws to get it tight and reduce the rattle.
Yup, mine was loose from day one and four thumbscrews is how I resolved it. What I like about the modification is when the table is down and extended you can snug up the two inboard thumbscrews and it holds the cutting board solid so it doesn't move around while you have stuff sitting on it.
Would you be willing to share information on those thumbscrews, where you sourced them, etc? Did you install a threaded insert for each of the thumbscrews?
Sure thing, here is a link to a write up I did a while ago which goes into more detail on how I did it and parts used:
Thank you very much. McMaster-Carr order inbound.
