Quartermaster Sliders/Step
Telemark
Quartermaster Owner
10:03 AM
Tacoma
Shout out to the folks at Montana Off Road Design. I installed their quartermaster sliders/steps on Sunday afternoon. These are well engineered and well built sliders/steps, install time was about four hours, no drilling or cutting required. I did chase the frame threads on the factory slider mounting points. The most important thing is my wife is now happy she has a step to use to enter the cab. :)
If you are looking for sliders, you might consider these well built slider/steps.
How did it take you four hours? My white knuckle sliders are bolt on to factory points and maybe took me an hour by myself. They weigh 80lbs each. Though I did install at less than 2k miles and live the SW so the threads were spotless.
I don't know the White Knuckle sliders, these have three separate mounts that attach to the frame, then the slider attaches to the mounts. You have to assembly everything loosely so the bolts from the mounts align to the sliders/steps, then tighten all the bolts, it takes awhile to assemble properly. I chased the threads on all the frame mounting points, mostly they were full of the wax Ineos sprays in the frame cavity. I'm happy with them.
