PSA: Wiring Pinch Point
ResponsiblyReckless
Forum Supporter
11:01 PM
Indiana
North American Spec Grenadier
I noticed the brake pad sensor and wheel speed sensor wiring has been sandwiched between the steering gearbox and pitman arm. The wire retention clip is zip tied in the wrong location and will not reach the designated location on the plastic fender liner / cooler cover. It might be worth it to check and see if your wiring is also rubbing!
