Portal Axles via LeTech as standard options. (Retrofit?)
MileHigh
That Guy
8:42 AM
Colorado
I saw on Reddit that there is going to be a portal axle option for the Grenadier? It looks like they are implying it would make it a $200,000 vehicle? My understanding was that the modification would be installed by the dealer, not factory installed. probably factory supplied, but not installed the factory. The numbers I heard were hoping that it would be a $15,000 option, I never thought it would be less than 25,000. It is interesting that I don’t see an actual dollar figure in the Reddit thread?
Does anybody know what’s really going on? I see some old threads on these axles, but nothing new?
It is an option from Letech:
So this is basically vaporware? I see the hundred and €170,000 price tag, that’s basically on top of any Grenadier wanna put it on? Plus, it has central air inflation? So this basically doubles the price? So this is isn’t actually a serious thing. Which I guess is why we aren’t talking about it
Don't forget the factory options also come with wider fenders, wider bumpers, larger brakes as well. Honestly if the factory order option adjusted HP/TQ I'd be a buyer, if not that thing will be dog top end highway speeds.
Am I the only one that thinks the Leech portals look light duty compared to the overall Grenadier build? I mean, they are certainly not Volvo C303 portals. So, I question their value and certainly will not throw money at them.
For the standard price of the Grenadier, I was willing to take a leap. Throwing a few thousand dollars at armor and other stuff I can stomach. Doubling the price of vehicle is something I’m not really interested in doing. Especially if we’re unsure on the future of the Grenadier.
That and I only have a 7 foot garage. So I’d have to park a quarter million dollar vehicle outside all the time.
Looks like Warner Ineos has a Le Tech portal axle Grenadier. This video gives a pretty decent look at it.
Looks like they're a 3-gear construction and add something like 5 inches (13 cm) to each side making for a rather ridiculously wide stance. I'm a bit skeptical about their ability to dissipate heat through the cast housings and performance at speed, but as we learn more I'd love to find that they're solid.
I'm looking forward to seeing what 74 Weld comes up with as they work through their full axle swap solution. Their portals usually add 3.5 inches of width when mounted to existing OEM hardware, but since they're swapping it all out it will be interesting to see what the overall stance ends up measuring. I presume they will also swap the brakes if the bolt pattern is changing along with everything else. Also worth noting that their gen 2 portals are built to accommodate a future CTIS system currently being tested.
Here's the 74 Weld video in case you haven't seen it. In a reply to a comment he says they got enough interest and are developing the solution.
I’ve seen estimates, but do we have real prices for these? Thom had a price in his head before it broke, I thought he was way low. I assume these are all more than $25k, which I thought as the minimum. It seems the LeTech/Ineos one is much more. And which ones are dealer installed?
Looks absolutely incredible. I'd need to upgrade my garage height first else I'd be all over this. Zero concerns if width is actually ~86". No wider than a Bronco or F150 Raptor. I'm sure they did their homework.
I first saw the portal IG in Seoul; black perfection.
View: https://youtu.be/5xGkyJfG3d8?si=TBqMIMSNrg7nPJWr&t=42
Nice, IA!
I think the Letech portals are really only designed for more off road work. They're not designed for normal highway speeds due to the planetary gearing
If only I could justify it 🤔
The crucial question is: Do you _want_ it? If "yes", then you need it.
More justification is not possible I think...
The real question is: How much is on-road performance affected? I mean, if the thing is only going 90km/h (don't know) after the mod, with all transmissions being close to their temperature limit at that speed, maybe that's too bad for a mixed driving profile...
