Portable Air Compressor Power?
So, I'm looking at Anderson plugs, the SB50, which uses 6 - 12 gauge wire, but the Nato plug that Agile sells is designed for 2 gauge wire. Can I use 6 gauge wire with that Nato plug, or will that cause me problems? Would rather not make this cable twice!
Thanks for your help!
I think you're using the ARB brushless single. That's a 15 amp load so you're well inside SB50 range.
I posted about making an adapter over here.
I have since commented that a butt splice cut in half lengthwise would work as a spacer to step down the wire gauges. Failing that, heat the plug contacts and fill the pockets with solder Preheat the ends of the 6AWG wires then plunge them into the molten solder pool. Hold until solid. This will work but it's a weaker solution because the solder is providing all mechanical strength and electrical conductivity. Not ideal but you're only using it to a compressor on the ground so it's not carrying much weight. Just be sure to fill the gaps in the rubber gland on the back of the NATO plug so it's providing strain relief to prevent the wires from flexing at the contacts.
Is the ARB compressor fused inside the case? The NATO circuit is fused at 350 amps. Consider derating the circuit if you are not using it for the rear winch. I'm using a 60 amp fuse.
Thank you, that is very helpful. My ARB compressor is fused, I'll have to check on the actual fuse amperage. I'm not planning on using it for the rear winch, but, isn't that outlet on the same circuit as the forward winch? I am planning to mount a winch on the front. Thank you again for your reply, really appreciate your time.
The 350A fuse in the pre-fuse box only connects to the rear winch relay, a.k.a the solenoid under the rear right side trim. I think it's been reported previously that the front winch has a resettable breaker or something like that. I don't have the winch option so I'm not familiar with that circuit. There is a red winches component mounted near the +12v jumper post.
Good luck with your adapter.
Thanks, good to know. I've only had the truck for 2 months, still learning the ins and outs, especially the electrical.
