Portable Air Compressor Power?
Seems like a good time to bump this. I want something portable and with the BF deals (despite already spending a shitload of money on the Panda today) it might make sense to buy something now.
I’ve never had a vehicle-based compressor and it won’t get tons of use. Besides ARB folks, can those with a different brand chime in?
I’ve now got a fixed ARB compressor in my Grenadier but my T-Max portable compressor served me well for a few years. At 160L/minute it’s good for large tyres
I’m about to buy a Viair compressor but haven’t decided if I should get the 400 line or just the 88 and call it good. Either way they have a plug I’ve not seen anywhere else that draws from the tow hitch plug! I’ll likely give this a shot unless someone sees a reason not to.
I go back and forth on removable versus on-board. I get the utility of the removable, but I know I’ll forget it and worry about it getting knicked. That and a strength of the IG is that it is set up to power on board items like the compressors. That and its just a couple of hundred bucks at each level of single and dual and then brushed vs brushless, and if you’re going to go through the trouble of putting one in…
There wasn't a lot of new info, but if it helps to clarify the choices Robert Pepper did a recent video on this very topic.
View: https://youtu.be/iCDNgkZUKE0?si=2DBlab2eV8vqvfkm
Also posted recently by @TheDocAUS
I need portability as I have multiple cars spread over 100m. And a caravan.
Plus I don't carry back seaters so can store the kit behind the driver seat in the Grenadier. I use the battery jump post.
I modified the cheap but beefy twin compressor with a pressure cut off switch.
Not as well-known as ARB compressors, but Extreme Outback compressors move a lot of air. Because they push so much air, they do run hot to the touch. All compressors that push out a lot of air run hot. That is why I choose to mount it the back of the G, open air, to assist with cooling. The extremeaire magnum that I have is 14 years old, has seen a fair amount of use, and I have had no issues with it.
I have the ARB dual suitcase. But I also have a cheap Chinese compressor that’s over 10 years old and cost $20 off Amazon. It still works flawlessly.
Great video. A great point about ‘hyper compressors’—you don’t need anything that extreme for a standard 4x4, and it’s mostly a waste of money. He also mentioned something that doesn’t get talked about enough: a tire plug kit. In my view, that’s essential gear. A good plug kit is far more important than any oversized compressor.
For the record, the compressor I use likely counts as a ‘hyper compressor.’ I’m still trying to understand how I became the guy who needs that much air. I keep telling myself it’s fine because it’s fourteen years old and I paid X for it—so technically, the longer I hang onto it, the cheaper it gets. ;)
again… the Milwaukee 18v is the way to go. I just did a few 35s 0-40 and it didn’t get the least bit hot. Ad on to that carrying an impact gun and grinder for repair, a chainsaw for deadfall.. or sawzall… I just don’t look back at the days of my York engine mounted unit. Sure it was fast, but, it’s just not an option on these engines.
I have Viaair 400 that I've had for years. It's been a good compressor. I put the onboard ARB under the rear seat in my Grenadier but still use the Viair in my other trucks. There were not as many options when I bought mine as there are now so you may find something comparable for less money with another brand...but it's pretty fast and reliable.
