Bingo. A perfect very snug fit. Very pleased with my eBay purchase from Australia and at around £45 inc postage it’s a relative bargain compared to prices from a mainstream tool supplier if you can find one.
Legend !!As we all know by now, INEOS spare parts aren't exactly cheap in the automotive world and are sometimes also not immediately available. It can't hurt, therefore, to have an alternative in case of need.
I've now found such an alternative for the front wheel hub nut (INEOS part number: GRA 5E00-021560), which is a special nut measuring M30 x 15, with a 41 mm wrench size and a 50 mm lower diameter.
This nut is intended for single use only and should be replaced with every repair. It is tightened to 375 Nm.
As -Logsplitter- painfully discovered, INEOS charges £105 or €120 for this nut.
Since the INEOS Grenadier uses the Carraro HS6.04 axle at the front and the HS8.06 at the rear, it seemed likely that this nut also came from Carraro.
That's indeed the case, and the nut is listed by Carraro under part number 135938. As a Carraro nut, it costs only £30 or €35 on eBay, for example.
I received two of these Carraro nuts with part number 135938 today. They are identical in all dimensions to the nut that- Logsplitter- received from INEOS.
Great discovery.As we all know by now, INEOS spare parts aren't exactly cheap in the automotive world and are sometimes also not immediately available. It can't hurt, therefore, to have an alternative in case of need.
