Noob question about the Gasoline Octane required
5:43 PM
Coppell, Texas, USA
I take possession of my Grenadier Trial Master in a few weeks, and just doing some research.
So Google tells me this below, and I've also seen videos say 91 is the required gasoline.
The 2024/2025 INEOS Grenadier gasoline (petrol) models are powered by a 3.0L BMW turbocharged inline-six engine (B58). The recommended fuel type is Premium Unleaded (91 octane or higher) for optimal performance, though it can run on a minimum of 87 octane if necessary.
Key Fuel Details:
  • Engine: 3.0L BMW Turbo Petrol, Straight-Six
  • Recommended Fuel: 91+ Pump Octane Number (Premium)
  • Minimum Fuel: 87 Pump Octane Number
  • Fuel Capacity: 23.7 gallons (approx. 90 liters)
  • Economy: Approx. 14-19 mpg combined, depending on driving conditions
The engine is engineered for high torque, utilizing the 3.0L engine to provide power for both on-road and off-road driving, often requiring premium fuel to maintain performance and prevent engine knock.
My question is: since this engine was designed for cross-globe "overlanding," there is no way 91 is actually required, and the above says 87 is the actual minimum, which makes sense. So "91" isn't required.
So the actual question is, does anyone have any experience running with 87 vs 91? I'm in the US and don't plan to do any cross-globe overlanding anytime soon, but I'm just curious about the recommendation to use 91 when it should run just fine on 87, since the vehicle is specifically built to operate in backcountry conditions on low-quality gasoline. So I get the recommendation, just wondering if anyone has experience, or a strong opinion on the Gasoline octane you prefer?
Looking forward to getting the new Grenadier in a few weeks, so any answer is welcome, just curious!
Most modern turbo engines operate more efficient on 91 or higher octane. Gas threads can turn into oil threads in a blink of the eye. The engine has software to adjust, though I am sure there are limitations there my guess is 87-93 is probably very safe range to play within. Me however I always prefer higher octane ratings. I like more performance etc....
" a strong opinion on the Gasoline octane you prefer"
I cannot speak to anything other than the fact BMW recommend 91 so that is what makes most sense to use. I personally use a higher grade than that but wouldn't go below the 91.
If you don't mind me asking, what's wrong with just using the 91? Sure, it might save a buck on a fill up but nothing substantial enough in my mind to go to a spec below what the manufacturer recommends.
Not enough data to be statistically significant. I ran 3 tanks of 89 to compare to the 2,200 mile baseline on 91 octane. On 91 I run 15.1 mpg hand calculated. The 3 tanks of 89 averaged 14.4 also hand calculated. No perceived difference in performance around town or on the highway. If I did the math right it was under $70 a year to run 91 with the mpg difference. I stopped playing with it.
Regular unleaded is 91 octane in Australia. Premium is 95, extra premium 98. No 87.
Use what the sticker on your car says. It will state what's correct for your country, but countries vary - so do your research when travelling.
That's a good point, its also different state by state here. lol
The question is far more complex than your inquiry suggests. Will your B58 "live" on cheap fuel?
Yes, it will also slowly die on cheap fuel. It is a pay me now or pay me later situation.
Top tier gasoline additive packages found in premium fuel will (along with 5k mile oil changes) will keep your engine running better longer and reduce wear.
Yes wear.
View: https://youtu.be/DAmEGI7xvBw?si=tPe-2L7athhleD_R
The Octane value did not show the caloric value and the mpg….
In Germany standard Petrol has 95 but you can but as E5 and E10 (5 or 10%) alcohol, and super+ with 98/100 octan (<5 % alcohol). Lowest MPG I have with E10 = highest caloric value
Octan is only needed for the „anti-knocking“ at high rpm
Yes wear.
Interesting video. I have 28,000 miles, and have probably filled up 75% 87 octane, and 25% 89 octane. I’ve never had an issue with knocking. This video makes a strong case for the benefits of lubricants added to the premium fuels. I wonder if the beneficial additives increase with the increase of octane and corresponding price? In other words, can I get the benefits of additives by filling up with 89 octane rather than 87, without going up the ladder to 91 or 93 octane? In my area gas stations typically offer 87/89/93 choices, skipping 91.
I talked with several mechanics about this recently and they all said the same thing. In most cases we won’t hear the engine knock on modern turbo engines. They have sensors to detect the condition and respond before we can hear it. They also said that the internal condition of the engine on 91/93 is pristine after many miles where the 87 results in build up and corrosion. 89 seemed hit or miss. I defaulted back to 91/93, figures it is cheap insurance.
Exactly. "Cheap" gas is a crapshoot with respect to the additive packages used which reduces deposits and buildup on the valves, pistons and rings over time.
