Next stop: Mauritania
After such a long trip and hard testing the vehicle, I would like to share my impresions with you.
The European version of the diesel engine is not valid for overlanding far in the wild.
Because of the non pollution regulations in Europe, the car is designed to stop when there are issues with the Adblue or the SCR. I have learnt also that if ABS sensors are disconnected, the car will stop.
The last thing you want in an overland vehicle is to be designed to stop with certain failures, specially contamination issues. An overland vehicle has to be designed to keep moving against all problema and issues, your life can depend on the car ability to move forward.
I think a remap in the offroad module that could cancel the Adblue would ve very welcome.
Propshafts have to be redesigned. CV joints are confortable, no vibes but perhaps U Joints are more offroad focused. Changing the caster angle in the front shaft would put more in line the front differntial with the transfer case.
Transfer case should hace to have a proper neutral in the shift and driver to be able to shift the transfer box into neutral from inside the car. When the car is stuck in mud, wáter, in the cresta of a dune, you can not get under the car
Hence why the Ineos guys at the open weekend, in the early days, steered me towards buying a petrol model.
Yeah, petrol avoid all the problems of the Adblue.
But in the other hand, miles per galón are significantly less.
In this trip I was travelling with 12 diesel Jerry cans. No way to carry 12 jerrys full of petrol. Too dangerous!!!
Thank you @Diego for sharing your journey with us, what a wonderful trip! (except for the headaches with the Grenadier)
You taking that 1.100km route without any chance of outside supplies is highly impressive.
As I am preparing for a (comparatively small) Morocco roundtrip with 5 Defenders and me in my Grenadier, I am highly curious to learn more about your setup.
Thank you for anything else you might want to share. From tire choice to suspension to water storage to sleeping setup to replacement parts to navigation and more, everything is interesting to me (and probably everyone else on here).
Thanks a lot!!
I only carried 5 x explosion proof jerry cans of petrol. The farthest I have ever been between fuel stops is around 600 miles
I’ve now got a90l auxiliary fuel tank and will keep 2 Jerry cans for reserve.
Alex, the Ineos engineer phone us to teach us a protocole of switching the engine off and on to clear the fault. We were at minus166 kilometers when he phoned us.
What a relief!!!
Diego, what was the exact procedure (protocol) to "clear the fault"? I guess not ONLY switching the engine "on and off", but probably something more? (pressing the brake several times? Something else?).
This is a really bad design flaw.
Are we talking transmission or transfer box? Could be a translation to english thing. Transmission, you can go into car wash mode. This allows you to move the car in neutral with the engine off. Same with running the winch without the engine on. You won't need to get your snorkle and speedo out.
also interested to know this
There was talk of a 'false' neutral by placing the selector in between high and low. Not tried it, but for sure there has been a very loose grinding of mine once or twice when the engine was on.
As for transmission - car wash mode, does that work when you have a 'dead' car or do you need power?
Need power, actually you need a running engine. The only way to shift it to neutral is engine running. Turn off and turn to ACC right away.
Hi Diego,
Well done on overcoming those problems and accomplishing an amazing adventure. I am hoping to learn from you for my 2027 trip to Mauritania. Great meeting you in Tanger Med and hope we will meet again in the future.
A question, once you cleaned the adblue injectors, did your grenadier start using adblue?
I had the same problem with Algerian diesel last year and I had to reset the error using an OBD computer once or twice a day. I was also able to use some Spanish diesel in a mixed fill and once I did that I did not get the error. Friends of mine in Eur 5/6 Hilux and Ranger did not get the problem -they were using Diphetane.
>john
