NEW PRODUCT NEWS: Grenadier 2.5" Game-Changer Suspension, RockSport Black Edition
Metalcloak
Supporting Vendor
7:24 PM
Rancho Cordova, CA, USA
The team at MetalCloak is proud to announce the release of our all-new 2.5" Game-Changer Suspension System, RockSport Black Edition, designed and engineered for the Ineos Grenadier.
This complete, bolt-on suspension system brings 15 years of suspension development experience from the Jeep, Bronco, and Ram markets to the Grenadier platform, combining comfort, strength, and precision geometry in one package.
🧩 What’s Inside the Game-Changer System?​
  • True Dual-Rate™ Coils: Provide a smooth on-road ride and superior load handling off-road.
  • RockSport Black Remote Reservoir Shocks: 2.5” aluminum-bodied shocks featuring Parabolic Valving (patent pending) and 8-position billet compression adjustment for true tunability.
  • Adjustable Duroflex™ Control Arms: Kevlar-infused flex joints allow up to 34° of misalignment for maximum articulation without binding.
  • Durotrak™ Adjustable Track Bars: Keeps the axles properly centered after lift installation and prevents steering shift.
  • Bump Stop & Mounting Components: Full-system design for geometry correction and suspension balance.
⚙️ Built for Real-World Adventure?​
The Grenadier was built to go anywhere... we simply made it ride and perform better when it gets there.
The Game-Changer System is engineered to enhance:
  • Ride comfort on-road and off
  • Stability under load or towing
  • Articulation and traction on uneven terrain
  • Long-term durability and serviceability
Every component is manufactured and finished in the USA, using DOM steel, gold zinc plating, and Mil-Spec anodized finishes for long-lasting corrosion resistance.
📏 Specs & Fitment?​
  • Provides a true 2.5" of lift front and rear
  • Optimized for 35” tires with proper offset
  • Fully adjustable to correct factory geometry
  • Designed as a complete system... not a piecemeal lift kit
🧠 From the MetalCloak Engineers
“We didn’t set out to reinvent the Grenadier — we set out to unlock it. The factory setup is capable, but this system gives it the ride control, articulation, and confidence it truly deserves.”
📸 Learn More & See It in Action​
Product page: https://metalcloak.com/8228-grenadier-2-5in-game-changer-rocksport-black-edition.html
As always, we welcome your feedback...
I just happen to catch it before R&D started messing with it again... it IS sitting under its own weight in the image. The lift is disengaged. Those are not the KO2... they are stock size Bridgestones on the stock rims.
