New member, Melbourne, Australia
James McIntyre
Quartermaster Owner
6:24 PM
Australia
Hi all,
I picked up my Quartermaster a few months ago. Have since added a canopy, decked out for camping, courtesy of Trig Point.
Absolutely loving the vehicle and looking forward to some trips soon up into the VIC High Country.
I think the main enhancement i need to consider in the near term is a lift (I'll look through the threads here for tips).
Cheers, James
Hi all,
Cheers, James
James
Welcome aboard.
Helpful links here:
Want to spend money look here:
Lifts in this stuff, remember to look for QM lifts and not IG.
The simplest would be Eibach 35mm Pro Lift Kit with airbags for weight carrying assist. If the lift is too high, you could get tailshaft problems.
AIRBAG SUSPENSION
  1. Airbag Man suspension for the Grenadier and QM, both come in standard and 2 inch lift kits. QM kits here and Grenadier Kits here; and
  2. GrenX Polyair Grenadier Ultimate Airbag Suspension Kit here; and
  3. Polyair Grenadier Kits here. Standard and Lift Kits. Also available from PSR here.
SUSPENSION FOR THE GRENADIER
  1. Heasmans (Sydenham Sydney) can can do Polyair airbags, Bilstein suspension and wheel alignments;
  2. JMACX Alpha suspension (manual adjustment suspension kit here. Electronic model also available here) and GVM upgrades for IG and QM;
  3. Eibach 35mm Pro Lift Kit, look here (Standard, Heavy Duty and Extra Heavy Duty springs available);
  4. Eibach 35mm Pro lift kit/King Shocks package, look here;
  5. Eibach with external reserve oil reservoir here (IG and QM);
  6. Eibach anto roll bar kit here (IG and QM);
  7. King Shocks Set (4), look here;
  8. GrenX has a full suspension upgrade solution using Eibach springs, custom Bilstein shocks, Bilstein steering damper & rear air bags by Poly Air, look here;
  9. AIRBAG MAN suspension for the INEOS Grenadier here;
  10. Dobinson lift kit under development, look here (DMW uses Dobinson);
  11. SOLVE Offroad using Fox shocks and Eibach springs. Review here by @Braydo;
  12. LeTech Suspension system lift + 40mm (nearly AUD15,000);
  13. LeTech coil springs +40mm;
  14. Oleo-Pneumatic suspension for the INEOS Grenadier, shipped from France, also available at GrenX in AU;
  15. Tough Dog suspension, springs and dampers here;
  16. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITH winch;
  17. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITHOUT winch; AND
  18. Some US suspension options being discussed here.
SUSPENSION - GVM UPGRADE AU
  1. Expedition HQ GVM upgrade to 3800kg (Pre and Post Registration, but check), QLD registered cars only. EDIT: NSW GVM upgrade not possible at present;
  2. JRace Industries GVM upgrade to 4,000kg (Pre-registration) including rear axle capacity increase (Townsville Qld). Email: info@jraceindustries.com.au
  3. MORE4X4 GVM upgrade to 4,000kg (Pre-registration) here;
  4. DMW GVM upgrade to 3,900kg (Post registration) here; and
  5. Three GVM upgrade options for the Grenadier and QM from DMW here. More information on the kit here.
Please post a picture(s) of the Trig Point Canopy, as we only have the prototype posted.
Here are some pictures of the Trig Point canopy.
