Need Help: Power buss bar to rear cabin or not? Electrically inclined, please respond.
Rupert
#4082
11:42 AM
Dallas, Texas, USA
Prior vehicles, Land Cruiser, 4Runner, Discovery.....battery was always in front under the bonnet (hood) so I would run (fused both) 10ga wire direct from battery to a Bluesea buss bar in back. With the IG, the battery is midship so most likely no Blue Sea will be required but guidance would be appreciated. Specifically, I need to know where to attach these wires at the mid-ship battery. Ultimately, I will still have some type of BussBar in the back as I want my fridge and ham radio to always be hot. The factory power positions are not constant hot.
Please jump in and educate me. Many thanks!
Asnes, is this pretty obvious? Is there a ground readily available also. It looks super advanced under there so I am not certain what is what. I have the dual battery, the factory re-charger thing, and there are covers on top of everything thing so Iam not certain and with no guide, I am struggling. If you have a minute and would post a pic, taht would be helpful.
Early on I mounted a Blue Sea fuse block to the top of the LittleFuse bus bar with nylon nuts. I believe TinyRig is now making a bracket for this that mounts to the battery mount.
From this I was able to run power from the battery to the fridge, etc, and it was always hot.
Eventually I evolved to a Redarc system and moved the BlueSea to the top of the battery with a More 4x4 bracket.
