NATO on Quartermaster
DennisS1
Quartermaster Owner
8:12 PM
Red Cliffs
Anyone know the location of the relay that supplies power to the rear NATO plug on the Quartermaster model? Looking to bypass this with a 40Amp fuse to supply full time current to camper DC/DC charger.
The relay is in the right rear of the wagon and I’d guess it is likely in the right rear fender or under the bed. There isn’t enough room under the seats and the idea was to get it as close to the plug as possible. If you have the aux wiring, and you should with the NATO, then there is also another one under the right front fender with or without the winch installed.
I have not investigated specifically, but if you switch the overhead 500A switch, you will hear a relay click on the wall behind the rear seat. Not sure which side, but removing plastic panel behind rear seat should reveal. As i understand the 500A switch controls the NATO plug along with the front winch. I don't have a winch fitted -yet.
