My new Leitner light bar and Baja Design lights!
SkiBum1
GG-4567
12:42 AM
Chicago, IL, USA
I just had my new Leitner front light bar and Baja Designs lights installed. It looks flipping awesome!!
I have the red parking light hooked up to the Grenadier parking light switch so the red comes on with the parking lights.
I have the low beams on overhead switch 5 and the high beams on overhead switch 2! Works perfect and lets me use those overhead switches a lot! Which is very cool.
This was an expensive set up but worth it!
Excellent idea. Like the light bar, I am guessing it won't fit the UK bumper?
Should be exactly the same front bumper set up actually. There are two covers on each side of the license plate opening and under those few bolts should be the same four bolt openings to install this on yours!
Looks great. Are those the 6" lights?
They are the Baja LP6 Pro LED and I chose a red parking light set up but you could get yellow or blue. These babies literally light up the road like day light, it is amazing! They look really cool too and when hooked up to the overhead toggle switches, just fun as hell to flip them on!
The lights look like they stick out past the bumper???
There may be one in the pipeline that does if there’s enough demand.
Are you sure there is a difference in the front bumper in the UK? The Leitner system is on top of the bumper and bolts in where the entire bumper bolts into the front frame. It should fit fine. It does not impede the front license plate area if you have one.
Makes it an expensive exercise if you bump into a wall or car even at carpark speeds.
Probably so, but I will never do that. I guess my wife could, but we sit so far up we can see the front of the hood so the chances are slim. But man, these light look great and can blind a bat. Love them
A risk you are willing to take and it is your money after all.
I just hope some useless driver doesn't reverse into you
Did your front parking sensors become more sensitive after your install? I installed the bar and Baja Designs Squadron lights so might are smaller and don't protrude out like yours but the two front interior parking sensors (not the ones at the ends of the bumper) tend to go off for no real reason when I come to a stop. They will beep and flash on the screen and eventually stop but it is super annoying. Nothing else has changed at the front of my vehicle and this started when I put the light bar on so that is the only thing I can think of that would be causing it.
No. Nothing happened to my sensors. Maybe some wire loom is touching something or something in the sensor system is too close to the lights/bar or new hook up wires? Makes no sense.
I just installed my lp6 as well. Where exactly did you find the marker switch to wire in the parking lights. Scratching my head lol. Thank you
Thanks for sharing. Thinking of a similar set up. Did you get the wiring harness from BD along with the lights? Also, did you get the wiring harness with the lockout circuit? I'm not sure how much I need to worry about accidently powering the low and high beams at the same time (given it won't always be me driving and people love to play with the switches.
I installed a Leitner bumper light bar, after that my front parking sensor are on all the time does any body have this problem or
if have found solution for this
thanks
