More shocks available
Hi, does anyone know if there is anything particularly complicated with installing the fox shocks? I know about cutting into the liner in the front, but otherwise its just a straight up bolt-in application?
No wheel alignment etc needed?
I'm thinking i'm going to do it this weekend myself.
How did the install go thinking of doing this next week?
If the rain stops here, then my plan is to install it today.
Crazy times, rain this late in the year in sf bay area
Ok didn't get to install today. Buddy came over and needed me to wire up his off-road lights on his land Rover. Took a decent chunk of the day so my plan is to install next weekend.
Still not started. Found it that's the wife had booked painters to paint my house when I was traveling last week. If I'm looking I'll get on it on Sunday, but even that looks doubtful
Okay, so got the shocks installed today.
Took me 7 hours. About 2 hours on the first rear wheel and then 20 minutes on the second. About 2.5 hours on the first front wheel and 1 hour on the second.
Impressions? I think it drives quite a bit better better, much less sway, my tires are firmly planted and the vehicle drives more level on hard corners. I think this is an upgrade that was worth it.
Pro tip. No fender liner needs to come out. You can get to the rear top bolt from underneath the fender liner at the rear bottom area. Makes it easy.
A Dremel with a cutting wheel and the agile templates made it easy.
The front shocks top mounts where 56.5mm thick. The opening is 55.7mm. I had to use my angle grinder and take off just a little bit of metal to install them. Be careful and frequently dip the mount in water to cool it off.
It's easier to do the reservoir last up front. Cut the fender first with a Dremel cutting wheel. Then use a scissor to trim the insulation. Then install the top bolt of the front shock. Then the bottom, I used a jack on the axle to line up the bolt hole.
After this install the reservoir holder to the brake bracket but don't snug it up. Get the reservoir aligned and put on one mount then the second. The tighten up the holder on the brake line mount.
I set the dials on the shock to balanced before I installed them.
And that is it. Not too hard. Quite satisfying in the end...
I highly recommend a strong impact driver, it makes everything quite a bit easier. I have the DeWalt dcf891 which was perfect for this job. Then do final torquing with a torque wrench.
@parb if you can report back on hard / semi-hard braking on asphalt, and let us know if you experience a hard pull to the left, that would be appreciated. Dealer service department tells me that this is common on most stock units, and more noticeable after a lift. I definitely have it and it became very noticeable after the lift (to the point of feeling not safe as it pulls me into the oncoming lane). I'll be following up with both the dealer and Agile in the near future to see if there is any way to resolve.
I have this, but mine did it before lifting and after. I can get rid of it by several really hard stops. Then it's fine for quite a while until I take a long drive down the highway. Dealer told me they couldn't replicate 🤦🏻‍♂️. I'm curious if there is some defect in the brake system. That said, the anti squat numbers for the rear axle are atrocious at stock height and even worse when lifted. This doesn't help the situation.
This is the first I hear of this, Agile Offroad instructions do not mention this either. Just to clarify, you had to grind the steel shock mount on the truck? any concerns of rust?
I ground the shock itself, it needed just a bit of grinding to fit well in the top mount of the car. It was so close but not close enough that I could muscle it in by hand.10 seconds with my angle grinder and it went straight in.
You ground the spacer? Shouldn't be a problem, but keep an eye for rust. Maybe spray some rust inhibitor on it.
Next time I would suggest a decent sized crescent wrench and gently flex the mount open a bit. Pretty common issue.
I tried but I could not get it to move. I was afraid of really muscling it though.
The material wasn't protected from rust, I am pretty sure it was stainless. I was careful with temperature control so I wouldn't alter the materials hardness or screw around with the spacers connection to the shock body.
Overall I was far more worried about creating an issue with the shock mount on the frame than removing some material from the shock itself.
It is possible that using a crescent bar to open the mount would have been the better choice, I just didn't want to risk it. I've changed several shocks in my day and never had this issue before. We where two fairly experienced people and as both couldn't think of a better plan at the time.
So Ive been driving my fox 2.5's for a week or so. Only highway, country road and commute to work in traffic.
My impression is that there is less side to side sway than in stock. Mostly noted on sharp turns like off ramps at speed. The car feels "planted" and well connected to the asphalt. Really great improvement.
I have a loaded trunk with drawers full of gear, roof rack with awning and side molle with 20lbs of gear per side. I have the hidden winch bumper with the bull bar. So a decent amount of weight. I changed the front springs to the heavier load rated Ineos red springs (double red triangles) per dealer recommendations. No lift.
When braking hard at speed the front doesn't dive as hard as stock suspension, there is zero pull left or right. It just feels more controlled.
When driving over the dots on roads I hear them but I don't feel them in the vehicle regardless of speed. A very nice feeling.
I'm going for some real hard trails in 2 weeks with hours of washboard driving in the desert. I'll update my review then. But so far I'm very happy.
