LeTech: EXCITING!
Fidei Defensor
Contract Signed
9:03 PM
Winter Haven, Florida
@ADVAW8S
Have you heard anything back from LeTech? I'm interested in the ladder and my Grenadier is almost here (in the US, anyway). I saw your post regarding shipping a roof rack from a couple of months ago, but was wondering the cost of just the ladder and if it would be $300 for the crate. Not sure I want it that much. I have 2 NATO Jerry cans I'll need to figure out how to transport them without a roof rack or bars. I'd like to take at least one with me.
The Black Sheep Molle-mounted Gas Cans is very cool. Put them on the same side as the gas filler and you can transfer gas with a super-syphon wothout moving the cans!
3:03 AM
For the money you can hire a steel construction and welding specialist and still save something. It's not rocket science.
Reactions: CB
Cheshire cat
2:03 AM
Cheshire, UK
Just ordered the Rotopax diesel containers which can be mounted in the same way.
2:03 AM
I have Rotopax water and fuel containers. I regret those purchases, and I think there are better options out there. The one big advantage of Rotopax is their mounting options - so if that is your priority, then they make sense.
Cheshire cat
2:03 AM
Cheshire, UK
Unfortunate to hear that you regret the purchase. I could have got much cheaper versions but without any accreditation. What is it you didn't like about them?
CB
8:03 PM
Tennessee, USA
In the US, a company fabricating custom T-tops for boats can make it out of aluminum and powder coat it any color the customer wants.
Fidei Defensor
Contract Signed
9:03 PM
One thing that is absolutely useless here in the US is the "safety nozzle" on all gas cans. And the Rotopax are no different. I can never get them to work and they break every time I use them! I have hust ordered some simple SS nozzles to try out. Should get them in a couple of days. https://ai13.us/collections/best-sellers/products/all-metal-pax-nozzle
2:03 AM
Rotopax provide some really cool mounting options, so if that is the priority, by all means, go with them.
Most of my complaints are directed at the fuel containers. The water containers are easy to use, so I'll keep those, but still, the water containers (at least the ones I bought) are quite small for the price. I'm going to replace my fuel containers.
Complaints:
1 - Each of the ones I bought (2 water containers and 2 petrol containers) is two gallons. Price per gallon they are the most expensive option available. In retrospect, I would have gone with Scepter for both fuel and water (see the OD Green container below). They come in 2.5 gallons and 5 gallons - actually 10 and 20 liters - but as an American I don't really know what a liter is ;) I'm fairly certain that Scepter are certified - at least here in the U.S. (thousands of these are used by our military). Another option if these aren't certified in the U.K. would be the classic NATO container (here in the U.S. a company called Wavian makes these for civilian purchase - see the red container below).
2 - Its kind of hard to pour the petrol into the petrol-tank of the car, and I always end up with petrol on my hands. A funnel helps getting the gas into the truck, but for some reason, its harder to get a good seal on fuel canisters - but its relatively easy to get a good seal with the water containers. A little pump would make this easier and much cleaner.
3 - The problem getting a good seal is magnified in really cold weather (-15 to -20 degrees Centigrade). The caps that screw on and off the Rotopax are hard to undo and tighten in really cold temps. We only do two winter trips per year where we need to carry fuel, but its still an annoyance.
4 - The petrol containers swell in the sun. This seems to be worse when they are empty and contain petrol residue that expands as a gas in the heat.
Bottom line: I feel like there are other options that would work for my needs that are both cheaper and better.
11:03 AM
Any plastic jerry can or bladder for petrol gives me shivers , unless it's in a race fuel cell.
Quality metal jerry cans have never let me down.
Cheshire cat
2:03 AM
Cheshire, UK
Complaints:
Thanks for the feedback Stickshifter
I can only hope that in the more temperate climate of UK and the fact my truck is diesel, I will not suffer some of the problems you have. As the two 10 litre cans are now on their way from the US, it is too late for me to change my mind.
ddv
11:03 AM
Central Victoria, Australia
Complaints:
As far as using a pump to transfer fuel to vehicle is concerned I have found the simple Tanami pump to be great. Have a look at https://www.rv4x4.net.au/4x4-accessories/fuel-related/tanami-pump/
2:03 AM
Some of my problems are unforced errors, and could be resolved by remembering to stop in the middle of the day (on a winter trip) to gas-up - as opposed to doing it in the evening or morning when its super-cold, or just getting a pump - like the one mentioned in the post above.
Another thing I'll add regarding the water containers: these are really high quality plastic (what we call here "food-grade" - or something like that). There is absolutely no plastic-taste to the water.
ECrider
2:03 AM
Fitted the flip number plate bumper from Le Tech. Seems a bit more flimsy than I was expecting. Had assumed it would be metal but guess due to regs it cannot be. Works well. Total cost was eur429.51 plus uk tax of gbp97.91
Can't say it's value for money but as I say it's fit for purpose.
Bobby Mac
11:03 AM
Narangba, Qld., Australia
Nice. Weren’t they like eleventy million dollars though?
Nearly…. Just a shade under $2k total - my big splurge, but I just had to have it! It was still over $500 less (plus freight from Syd to Bris) to order it direct than get it from a Sydney supplier.
Pat-Ard
Global Grenadier #00520
3:03 AM
I‘ll get mine mounted on friday…
Bobby Mac
11:03 AM
Was it easy to mount/install?
Yes, just a matter of removing rubber plugs on original ladder, then undoing screws and removing it.
LeTech ladder supplied with 3 small and one large spacer. Large spacer goes in lower RH door orifice, small spacer lower LH, and other 2 spacers in mid orifices.
The best thing to do is then start the screws in their threads but leave all loose until they are started - long screw lower RH, mid length screws lower LH and mid, and small screws in upper orifices. These suppled screws have Allan Key heads.
That’s all there is to it.
Global Grenadier 0076
9:03 PM
It's a nice looking bit of kit. I am unaware of Letech's NA distribution abilities, but I'm a big fan of their roof rack setup. Not priority one for me, but is certainly on the wish list.
