Kill Switch from Fuel Pump
WanderingSniper
8:13 PM
Los Angeles, CA, USA
Hi all,
To my knowledge the only kill switch discussion is about the Ravelco which I"m not putting on the Grenadier (although it's on my other cars.) I want to install a dedicated kill switch from the fuel pump, so that even with my key the truck still can't be driven off easily. Obviously anyone can do anything with enough time, but this is one more step. I bought a switch from Concord Aerospace (SCE - AUX for all that get it) and want to install it overhead in the blank space. Can anyone explain to me if this will work (our fuel pump needs a chip from the key) and how hard the wiring might be?
Thanks
Or pull a fuse/relay
Hi all,
Thanks
I fitted a Throttle Control device. One of the settings allows the engine to start but locks the throttle in idle mode... the engine does not respond to the accelerator pedal....
Or you could just move away from Los Angeles to a place where people don’t steal cars.
Calling them 'stolen cars' is so passe as it implies an illegal activity has taken place. Fortunately, Los Angeles DA's have removed the inconvenience of being charged with crime - to better support those who are merely liberating resources for deployment elsewhere.
That would be far, far away…
Hog wash!
I’ve lived in more parts of Los Angeles, and Orange counties than I care to count. And while I never had a car stolen from me, I would never go back.
More recently I’ve lived in San Luis Obispo county and find it a refreshing cowboy frame of mind.
Still you couldn’t pay me to live in California.
Now in attempts to REALLY escape the garbage I spent 10 years living in central and north Idaho.
Keeping far enough distance from Boise, Twin Falls, and Spokane (Especially Spokane…) I found peace.
I’ve since lived on Maui (garbage)
And now found myself settled in South West Victoria Australia. All in efforts to get as far as possible away from the stupidity and decay of western society.
Unfortunately I don’t think it’s possible to completely avoid, but I’d say this is as close as I could get. Bottom line. At all cost. Escape from LA…
Hog wash!
@LeftCoastOverland : Port Fairy ---wonderful place. The next annual Jazz Festival - Feb 2025 ---fabulous!!:love:(y)
Hog wash!
When the rest of world seems like its all assholes, and you’re the only sane man, you may wish to step back and consider the issue may be one of incorrect perspective…..
Hi all,
Thanks
I haven’t seen anything that someone’s done yet for this. It may be an idea to ask @rusnak for help with regards to the electrical schematics or as mentioned above pull a fuse in the interim.
It's easier to pull the wire from the coil to the distributor.
Couldn't you just have a relay wired in and then the overhead switch to trigger the relay
While appreciate the moving out comments I’m stuck in CA. My profession is based here as is my wife’s. We could move…but then I couldn’t afford a Grenadier in the first place. As for the kill switch I’m interested to hear more about either the relay or the coil if you can elaborate. I’m going to look into the throttle idea right now though….
I assumed that the “coil” suggestion was just a quaint throwback to much earlier times…
Hog wash!
I could drink a beer with this Man!
Hi all,
Thanks
Hi - did you ever move forward with this and get a kill switch wired in ?
I was considering the under seat fuse box possibilities:
- FI18 Fuel Pump 30A fuse or
- FL01 IGN Relay 30A Fuse
... then adding a fuse holder & in-line switch close to that fuse box location.
However... not sure of the ramifications to the vehicle of putting a switch in series with either of those fuses / warning lights or other electrical issues it may cause.
Any thoughts or advice anyone ?
Ian
