Key Fob Not Working Properly
LeftCoastOverland
12:44 PM
Port Fairy VIC, Australia
Hey, just wanted to see if anyone else was experiencing this issue.
So the car locks fine with the central locking system when I press the 'Lock' symbol on my key fob.
However when I return from the shop, or the next morning - whenever to Unlock the car, the system isn't recognizing the button press.
I must then press the 'Lock' button again, which gets the headlights to react, and I hear the mechanism confirm the lock, I can then subsequently press 'Unlock' shortly after, and the system recognizes the unlock demand.
Not sure it's a problem with battery life - as the lock function works flawlessly.
I did get re-keyed due to the sticky buttons a month or so back. It's been working normally for the last three weeks up until now. not sure if that may be related.
Thanks for reading.
-R
Thanks for reading.
-R
Does this happen with both keys?
Thanks for reading.
-R
Same issue with mine. I swapped keys with the Mrs. and her's is fine. Not worth a trip to the dealer, but it's annoying.
I received an alert on the dash the other day that said something like "Keyfob battery low" so I changed it of course. It was only 2-1/2 months from date of purchase, but I presume it had sat around on a shelf for a year or so.
I’ve also found that I need to press the unlock and lock for a beat and not just a quick click. That’s solved any issues with the fob not working.
