Infotainment system
  • Thread starter Thread starter aj
  • Start date Start date
Hi , thanks for the response’s but next to the ODO I have the range left in the tank ?
That's just one of the options you can choose. You can scroll that one. In the display settings you choose what you all want to see in the scroll menu.
Just go with the big wheel to the left until you can select it. Then the scroll symbol will come up.
Thanks, I’ll give it a go! Sadly mine was delivered with an Italian owners manual…. 🤷‍♂️
Does anybody know whether it is possible to set the trip distance (from the last fueling) in one of the selectable fields?
As far as I know: NO. I also searched for the function.
I have an Excel sheet where I write down this information. (Did this with all my cars).
[EDITED] My previous car, Suzuki Grand Vitara, had two resettable trip meters, and one of them I used exactly for that.
there are 2 trips, one from last manual reset (could be done at refuel) and the other from last journey start I.e. trip for the current journey. Although the second one won’t reset if you stop the truck for say half an hour and then continue your journey. It’ll show the total elapsed time/distance.
I think it should, but this function is not (yet)active on the screen.
It’s mentioned in the user manual. Maybe after the software update?
MEDIA AND INFOTAINMENT
VEHICLE FUNCTIONS DEFINITION
Instrument Illumination Set the brightness of the illuminated instruments.
Settings can be set by the user, such as, Drive away locking, Selective Locking, Leaving Home Central Locking System Light Timeout, Remote Lock Feedback, Auto Door Unlock, Follow Me Home and Re-lock Remote
Unlocked Door.
Park Distance Control - Front Deactivation Here the front PDC can be deactivated, resulting in the four front sensors being switched off.
The user can see information, such as, Engine Oil levels and temperatures, AdBlue levels, Tyre Vehicle Information Pressure, Battery, Service Intervals, VIN number, Total Distance Driven, Software (SW) Version
and Active Warning Messages.
Speed Warning Sound An acoustic warning sound will be heard when the vehicle reaches the set speed.
Passenger Airbag Here the Passenger Airbag can be switched off or on.
Daytime Running Light Daytime Running Light can be switched off or on.
Trip Information Shows trip values for TRIP A and TRIP B. They can both be reset individually.
Reset Vehicle Function Settings
Resets all vehicle function settings to the default values, the user will be asked to confirm before resetting.
Acoustic Settings
The 'ACOUSTIC SETTINGS' menu consists of the following options:
Unlocked Door.
Acoustic Settings
Thank you. I use it exactly with this way to get the information right now. But it would be nicer to see the trip data on the screen. For example I normally do not need to set the date there as I mostly know what day it is...
