Hood decals
billcarbz
8:58 PM
Miami, FL, USA
Got my decals today….. It’s like adding a little color to my life all for less than $100 clams…. #♥️
After and before shots….
Any tips on application?
I had it done by a professional for $75.. I could’ve done it myself but I didn’t want to screw up a letter and have to de-order the decals.
The tolerances between the decals and the embeds on the vehicle are a little different and so positioning required a little skill.
A spritz of Windex or a 10% water and isopropyl alcohol (rubbing alcohol) solution on the sticky side of the decal will allow you to slide the decal into final position before the adhesive sets. You can also buy decal application spray on Amazon and elsewhere.
I used the etzy decals but didn't bother wetting them. I used two pairs of blunt forceps (tweezers) to hold the decal above the surface until I was happy with the position then started with one corner down and worked across the decal. They will lift off again if you don't press hard until you're happy with the position. A steady hand helps.
오늘 데칼을 받았어요... 100달러도 안 되는 가격으로 제 삶에 약간의 색상을 더한 것 같아요... #♥️
촬영 전, 후…
Hi,
the decals are very beautiful.
How to install them, do you rivet them to the fender? Or glue them?
Is the material plastic?
If it is plastic and doesn't need riveting, I would like to buy a set from Korea.
Thanks. a lot !!!!
Hi,
Thanks. a lot !!!!
They are vinyl decals with a self adhesive back (they're stickers) - just peel and stick!
