High Load wiring Locations
Tom D
6:20 AM
Berwickshire
I've been trawling the forum, looking for the wiring locations for the Aux wiring. Can't find what I am looking for.
I need to rewire the signal to the rear relay for the 500A circuit, I need this co come on with the ignition. I'd prefer to splice into the loom under the seats to save removing my drawer system to access the relay directly. But I need some better information.
Sadly I can't find anything in the workshop manual.
I have seen an image that shows the wiring locations but can't find it now...
Any help appreciated.
A slight update: I have discovered that there is a pre-relay relay.... So I should be able to intercept it there under the seats, this will make life a lot easier..
I'll update once I have figured it out for sure.
Details for the wire ends here:
Just download the PDF file. Plus Rok Dr Guide has lots of information on the electrics.
There is a separate post on the rear relay and I will try and find it.
EDIT: these earlier schematics may also give you information here:
It looks like you solved your problem in another thread you posted here?
Thanks Doc, I found those docs yesterday thats how I got the pre relay relay.. Really helpful. Interestingly there's no wiring diagram that I can find in the workshop manual..
