Headlight plug
Wazza
4:09 AM
Has anyone piggybacked onto the main driving lights? How did get access to the rear of the light? Is there a trick to get to it?
What type of connector is it?
You get to the back of the headlight by going in from the front. Pull off the trim at the front, then unscrew the light and remove.
See the pic below for the connector.
The orange connector is for the lights and I think the white connector is for the levelling system.
I haven't been able to find a piggyback connector.
Ok, thanks. That's a Deutsch connector, I'll be able to work with that I think. I can modify a piggyback connector to that. Thanks for the tip on getting access to it.
...OK, just to get this correct. Are you saying the aux driving lights can be removed from the front without disassembly and removal of the complete front grill?
The DEUTSCH DT is for the light, the Sumitomo for the height adjustment. The only source for the Sumitomo I have ever found was a dealer in the UK.
AWo
Have you got a picture of the back of the connector with wiring harnesses. ?
I built a simple jumper harness to access the high-beam wire. I use that to enable a relay for my Baja Designs driving lights. Two Deutsch connectors back-to-back, solder/crimp connectors and marine shrink tubing. That way, I don't break the factory wiring harness anywhere.
