Statistics/Poll Thread: Front driveshaft CV joint failures
1:43 AM
Virginia, USA
CV failures
Station Wagon:
2 Stock, 18,062 average miles at failure, 100% covered by warranty
1 Lifted , 18,000 average miles at failure, 0% covered by warranty
Quartermaster:
Stock - 0, 0 average miles at failure, % covered by warranty
Lifted -0, 0 average miles at failure, % covered by warranty
This first post will be updated with a running tally of failed front drive CV joints for information purposes for the good of the community. Please do not use this thread to discuss causes, ideas, replacements, Fosters, or which tire width is preferred. There are other threads for that. If I’m missing an important data, please let me know.
If YOU have a failure, please add a post on this thread with the following information:
Year, model, stock or lifted suspension (if lifted, how much, and approximate mileage lift was installed), mileage at initial failure, did warranty cover repairs, and type of driving (ie, 20% heavy off road, all road miles, etc.), and type of failure.
Year: 2022
Model: Station Wagon
Suspension: Lifted 2 inches, installed at 5,000 miles
Mileage at Failure: 18,000 miles
Warranty: No
Driving: 50% off-road, rough trails
Year: 2023
Model: Station wagon
Suspension: stock
Type of failure: Lubricant leaking from the end cap.
Mileage at failure: 13,000km / 8125 miles. Monitored then replaced at 21,000 km / 13,125 miles
Warranty: Yes
Driving: On road
Model year 2023
Station wagon
Stock suspension
Roughly . 28k miles
complete cv joint failure caused I’m told by C-clip failure causing damage to gearbox, transfer box cable, oil pipelines and thermostat, heat shielding etc. . Ultimately new gearbox, transfer box cables etc .
This happened two weeks after a service at around 30mph On a tar road.
Repaired under warranty.
Model year 2023
Station wagon
Stock suspension
Roughly . 28k miles
complete cv joint failure caused I’m told by C-clip failure causing damage to gearbox, transfer box cable, oil pipelines and thermostat, heat shielding act. Ultimately new gearbox, transfer box cables etc .
This happened two weeks after a service at around 30mph Ona tar road.
Did the warranty covered all related repairs?
2024
Wagon
Stock suspension 35” tires 255/85r17
12,000 miles CV boot rip. Front driveshaft replaced under warranty
Daily driver with about 15 percent off road use including use that fully articulates suspension
Year: 2022
Warranty: No
😳 Wow year 2022 build in the USA. Is yours a prototype Grenadier. ?
